Results 1 to 4 of 4
Thread: Stock tires on wider than stock rims?
    '01 Ebony #0939
    Has anyone here for whatever reason ever put a set of the stock 245/60-18 Bridgestone Duelers on a set of aftermarket 18" wheels that were 8" wide? I've seen that 8" wide rims are the widest width recommended for that size tire, so it will apparently work, so I'm just curious if anyone has pictures of what such a setup would actually look like.
    Jul 2009
    Are you considering a wheel swap with stock tires? The wider the rim, the lower the sidewall height will be for the same tire. FWIW, I've always thought the stock rim and tire combination of the 18" chrome rims was a killer look, although a bit too "street" for some...I'm sure someone has pics and suggestions regarding your intended look. I'm curious to see the results.
    Vixer Fixer
    I'm thinkin' you'd kind of be heading toward rubber band territory as the stock tire "stretches" to cover that extra inch, and flattens out the sidewall (as Scott said). Run it on "rims-n-tires.com" visualizer to help you with the visual.
    '01 Ebony #0939
    Basically, it's not an intended look I'm going for, just a matter of curiosity for what's possible with what I have lying around. Thanks for the link Kat. I'll give it a try.
  1. Biggest tires on stock rims?
    By Lavx0642 in forum Wheels and Tires
    Last Post: 01/15/2016, 10:48 AM
  2. Replies: 21
    Last Post: 04/03/2014, 02:21 PM
  3. Fit 4 stock '99 rims and tires in back of VCross
    By yellowgizmo99 in forum VX Talk...
    Last Post: 03/19/2010, 07:04 AM
  4. Stock rims: what tires?
    Last Post: 06/15/2004, 03:06 PM
  5. Replacement tires on 18" stock rims
    By Ebony1433 in forum VX Troubleshooting...
    Last Post: 10/21/2003, 12:07 PM
