I just got this Vehicross, and it's giving me TOD codes 13, 14, and 24. I went through the troubleshooting steps in the manual and I've narrowed it down to a wheel speed sensor.
So... how do I remove it? I removed the bolt and I could barely move the sensor. I saw in one post that it's tight and may need to be rotated back and forth to get it out, but I couldn't move it more than about 3 degrees. Is there some trick to getting it out?
I also had trouble getting to the connector on the top of the transfer case. Is there some way to move it to get access to it so I can replace the speed sensor pins if I ever get the sensor out?
Or should I just drop the transfer case to get better access to everything. It doesn't look too difficult, but if I don't have to, I'd rather not remove it.
Thanks.
