Results 1 to 15 of 24
Thread: grinding/rubbing sound when turning...need help! please please!
    Aug 2012
    1999 Silver VX
    Ok
    so this will be a bit of a long post but I want to give all the details.
    When I take a left turn there is a grinding/rubbing sound coming from the front right/Passenger side tire.
    It sounds just like the wheel rubbing on something but it just started out of the blue and I've had these tires on since I've owned the VX.
    So I sprayed some removable paint all inside the fender well to see if I could see any marks...nothing.
    Rotated the tires to see if the tire was the cause and it's still at the right front.
    The sound goes away the second I touch the brakes so I assumed it was brake related
    Changed the Brake pads...still there.
    New Caliper!...Still there
    New Rotor!!! and packed the bearings <---Bitch to do lol ...still there
    WTF!!?? the CV joint would be my next target,but like I said the sound goes away when I brake.
    Also it's getting worse and it starting to do it when I drive straight...
    Any help would be great. please...it's driving me nuts!
    My vote is CV.
    Feb 2013
    2001, Silver, Base, Stock,
    I second this. you should be able to tell right away if the boot is ripped or if you jack up the front and spine that tire when it is turned. you should be able to put your hand on the joint as you turn and feel if the issue is at that location.
    My vote is CV.
    Aug 2012
    1999 Silver VX
    Well the CV is not riped and looks fine from a visual inspection.
    That will be my next target to change out.
    Only reason I didn't do it yet was cus it went away even from the lightest tap of the brakes. second I let off the brake it comes back.
    01, LineX tan/black, 1055
    Hmmm, those symptoms really really sound like wheel bearings. Did you do the inner and the outer bearings? I also thought our bearings were not really repackable? When I went to the Isuzu stealership a long time ago, they said they should be be replaced, not repacked.
    I second the recommendation for checking the CV joint, but if the boot isn't ripped, it should be fine.
    Just for giggles, you can also check two more things:
    1.Check the front diff gear oil level
    2.Remove the ABS fuse and see if the problem clears.
    Jan 2013
    2001,custom,#0947
    same thing happened to me and itle get louder and louder. id it is the cv, id change that asap. I slacked on mine and it ended up eating away all m y bearings, and everything elce. so get that checked first bro. just a friendly opinion
    Mar 2012
    sold
    sounds exactly the same as when my transfer case went bad - everyone kept trying to tell me it was my cv but it was not
    1999, Ebony Black, VX, 1614
    It could be the bearings on the opposite side of what you thought. We swapped out bearings on all 4 wheels of my wife's car until we got to the correct wheel. We kept thinking we could hear it in the wrong wheel. Sounds travel weird.
    I think it would be weird for the transfer case to be the issue when the noise is in the front?
    But as Jamas said, noise travels weird, put it up on 4 jack stands and see if you can replicate the sound while you stand outside. That is how I figured out it was my Trooper's rear wheel bearings vice the differential. It really sounded like diff noise inside the truck, on stands, it was obvious it was from the wheels.
    Mar 2012
    sold
    my noise sounded like it was coming from the drivers side front wheel - at least thats what it sounded like when inside the vehicle - had to get out and have someone else drive it to tell it was really coming from the middle - still never really sounded like the tcase, but having it rebuilt fixed it - hopefully with hcloud it is something less expensive
    started out pinging and occasionally popping, then got worse and would sound like rubbing and as if it was going into 4lo when i took a sharpish corner (like pulling into a parking space)
    i know what cv's going bad sound like and this was a different animal - i almost thought it was something wrong in the steering box or power steering system but that all checked out fine
    2001, Ebony Black, 1153
    When were the front wheel bearings last repacked? I would try repacking front wheel bearings or replacing front wheel bearings, and then CV. To check your CV's just put it in 4-Low and take a sharp left and then right turns. If you hear/feel clicking or grinding, that would be your CV's. If not, I am thinking bearings. But then again, I would check ball joints, steering links, sway bar connections, and shock attachments, just to make sure it is not a weird alignment thing.
    That'll only check your outer CVs. Inner CVs are only mildly stressed in turns. They are stressed in situations of suspension flex.
    Cloud, I'm thinking bearings as well. The easy test for this is to jack up the front and jiggle the whole wheel assembly top to bottom. If you get any play, then the bearing pre-load needs to be adjusted (or bearing replacemnet).
    I always start with the simple stuff & work towards the harder. Since you've already checked the brakes & CVs (I assume all 4 & not just the outers), pump some grease in your U-Joints, check fluid levels in the transfer case, tranny, front & rear differentials. Have you had an alignment done recently? If not, then do so (that shouldn't make a grinding sound but if caster is way off, then you may have a tire touching something in a turn (ask me how I know)).
    Jul 2011
    1999 Silver VX
    Let me resurrect this one with a problem I'm having... So I replaced the both inner and outer wheel bearings up front,/both sides, the the "grinding noise got A LOT better (it doesn't shake my entire front end when in 4 low & never happens in "HIGH") But now, when in 4 low if i turn the wheel while riding brake or just ride the brake, I get a slipping/clunking/grinding noise from up front. placed on lift, let all 4 fly in 4 low, turned wheel...nothing...start to ride brakes...noise comes back??? any ideas???
    Quote Originally Posted by magikmike View Post
    UMMMM ... brakes????
    If your brake pads are in good shape, you could still have a warped rotor. Have rotors turned or replaced & replace brake pads while you're at it.
    ^^^^ x2
  1. horrible grinding when turning
    Last Post: 03/14/2015, 06:48 PM
  2. Grinding while turning with body roll
    Last Post: 05/21/2014, 10:22 AM
  3. grinding sound, like worn pads grinding on rotor but now
    Last Post: 05/15/2013, 11:45 AM
  4. grinding while turning
    Last Post: 02/07/2007, 07:25 PM
  5. Banging sound when turning
    By VX1 in forum VX Troubleshooting...
    Last Post: 10/28/2004, 10:22 AM
