Results 1 to 6 of 6
Thread: Rancho shocks problem?
    Mar 2003
    1998 Blue standard 1198
    Are the rear shocks designed to fit upside down, it would appear that the bushes are the wrong way around the guy installing them is going to change the bushes around.
    Not as far as I know. I put on OME shocks that replaced OEM in front and Rancho's in the rear. If I remember correctly the Rancho's were right side up.
    01, LineX tan/black, 1055
    Yes, they are right side up, only difference front to rear is the direction the adjusting knob faces. Front shocks face rearward, the rear shocks face forward.
    I had no problems in the VX or the RS.
    Mar 2003
    Thanks everyone as far as I can tell the bushes were inserted the wrong way round from the factory
    The OME shocks came without the bushings installed. I don't know if Rancho does the same. A couple of mine were a PITA to press in by hand ... but doable. So if your bushings need to be swapped top to bottom, it shouldn't be that big of a deal.
    Jul 2011
    1999 Silver VX
    mine came like that too... I just pushed the bushings out use various washers/sockets... and a bench vice... re-installed them the correct way... just slows you down. You can send them back to rancho, but there may be a chance you get a new set with the same issue. I read NUMEROUS threads on a bunch of different forums as far as mounting them upside down, it was a 50/50 split pretty much, so i just decided to swap them myself.
  1. Shocks - Rancho 9000xl
    By VehiX in forum VX Modifications...
    Last Post: 03/27/2015, 09:59 AM
  2. Rancho Shocks
    Last Post: 01/29/2015, 01:26 PM
  3. Rancho shocks
    By Otto in forum VX Talk...
    Last Post: 03/15/2012, 04:25 AM
  4. Rancho Shocks
    By I_Wanna_Retire in forum VX Talk...
    Last Post: 04/12/2007, 07:24 PM
  5. Rancho Shocks For 2" BL
    By JULIAN911 in forum VX Modifications...
    Last Post: 11/02/2005, 11:03 AM
