Results 46 to 54 of 54
Thread: Rotella Trials
  1. #46
    Nov 2013
    2000 Ebony VX 0750
    So its been more than 6 months since the last post. Where is everyone at now with their oil consumption after making a change to Rotella? Or after the MMO trick?
    I'm just curious as I seem to have to add anywhere from a 1/4 to 1/2 a qt everyday. I drive highway to/from work for a round drop of 50 miles and the speeds are average around 65-70, I do my best to keep the rpms under 2500, but sometimes you have to pass people lol. It's rather annoying as everyone knows. I love the VX, but I'm getting to the point of do I put $20 in the gas tank or $10 in the tank and $10 in oil? lol.
  2. #47
    Jun 2007
    2001, Proton
    I burn oil too
    Haven't done the Rotella but I do use Lucas motor treatment it is thicker and slows usage. However I am more around a quart every 1000 miles you definatley have an issue above and beyond the heavy oil use.
    Carter Pewterschmidt
  3. #48
    You can also try to replace your PCV with an oil catch can. Opinions are varied on it's effectiveness but I've been running one on the Amigo for a year now and seem to burn less oil.
  4. #49
    Nov 2013
    2000 Ebony VX 0750
    It's weird. When I first bought mine i only had to add about a 1/4 every fill up so... 250 miles. I've owned it for a just a little over a year and has progressively gotten worse. To the point of I almost want to get rid of it. randomly though it won't use any. Such as I checked it monday and had to add a 1/2qt. Then it went down about a 1/4 from the full like on the dip stick (didn't add any oil) and it stayed there the next two days, then thursday I had to add a 1/3 of a qt and then 1/4qt this morning. My driving distance or style didn't change at all though. I'd love to take a road trip in it, but scared to lol. Now if I could put in an oil level sensor in the pan and then a fill tube in the glove box so I can fill it while driving... I'd be okay lol.
  5. #50
    Jun 2007
    2001, Proton
    Imho
    Quote Originally Posted by GAMEON View Post
    Find and fix the leak this is way more than the typical oil burning.
  6. #51
    Nov 2013
    2000 Ebony VX 0750
    There is no leak. I have checked under the vehicle, valve covers, oil pan and everywhere else for any signs of leakage. there is none.
  7. #52
    Jun 2007
    2001, Proton
    that is a good start
    But there are places it could leak that you can't see. A pressure test is the only way to be sure. That oil has to be going some where I do not think it could even burn off that quick. But hey just giving my opinion.
  8. #53
    Nov 2013
    2000 Ebony VX 0750
    It's not in the coolant. I would think by now that if it's hiding somewhere in the engine it would be leaking out somewhere by now or there would be a hole in my block lol. The undercarriage is clean from any and all oils also. I just purchased some products from BG Products to put in the oil. Gonna try it next week and see what happens.
  9. #54
    Mar 2015
    Thanked: 34
    Just saw this thread. I'll chime in that I swear by Rotella-T full synthetic. I use it on my Mitsubishi GTO & I'll be using it on my Vehicross. If you have oil burning problems that seem to get WORSE with Rotella, that's probably because your engine needs major work. Rotella has SUBSTANTIALLY more cleaning agents than conventional "gasoline engine" oil--because of federal regulations that limit the detergents in "gasoline engine" oil. In reality, a 10w30 is a 10w30 regardless of what engine it goes in. Those higher amounts of detergents in Rotella-T full synthetic are going to clean out a lot more gunk between changes than other non-diesel oils.
    Part of the problem is that on older engines, there is already more gunk inside the engine, and the detergents may be entirely used up in the first 1,000 miles of an oil change interval--meaning that for the remainder of the time, you're just adding MORE gunk back into the engine. This is even worse when you use conventional oil instead of FULL synthetic...because full synthetic is much more homogenous & much less prone to sheering forces, etc (and complex engine physics that would probably bore you to tears). I change my oil usually every 3-5,000 miles with Rotella-T and I never seem to have any problems as a result. Same reason why I completely flush my transmission fluid every 15,000 miles--also with full synthetic. (My trans fluid looks nearly new when it's being purged).
    Not even the best oil filter in the world will save you from the negative effects of using a crappy motor oil.
    / my $.02
  1. Ryan (Littlebeast) progress at Olympic trials
    Last Post: 06/24/2012, 12:10 PM
  2. Trials Trucks = BIG Fun
    By ZEUS in forum Chit-Chat ...
    Last Post: 12/23/2010, 07:06 AM
  3. Rotella by Shell
    By Gussie2000 in forum VX Talk...
    Last Post: 04/04/2010, 10:19 AM
  4. Little Beast olympic trials????
    Last Post: 07/01/2008, 12:21 PM
