Results 1 to 8 of 8
Thread: Engine shuts down
    Jan 2010
    1999 Astral Silver
    Engine shuts down
    I got some work done recently on my VX, including transmission service and fuel filter change. It drove fine about 50 miles after that. I then have cleaned MAF Sensor in attempt to get rid of "lean during acceleration" CEL, and went on what had to be a 200 mile drive. Engine shut down after about 30 miles right in the middle of freeway. All dashboard lights went off, headlights and emergency lights still worked. Engine wouldn't start after that, with no dash lights coming on when i turn the ignition, but the starter would engage (to no effect). Tried disconnecting battery and wait 5 minutes, but no dash lights and starter working repeated. I then checked all the fuses and unplugged / plugged back in all black cubes (ECM, Starter, etc) in fuse box. The engine then started but shut down again half a mile later, also producing check TOD CEL, lights. And then I was back to no lights on dashboard/ starter works situation. I then called AAA to tow me back home.
    Can anyone advise on how to diagnose this? I have not looked at stored codes yet, but CEL light is not currently on (after reconnecting battery and re-pluggin black cubes). I read some threads here that tied similar problems to fuel filter, but my mechanic is very certain its not, and is an electrical problem. Appreciate any pointers, thank you!
    Battery ground cable...make sure it is connected and make sure there is no corrosion
    May 2003
    Wink
    If the above post doesn't help...check the ground terminal under the dash IIRC on the passenger side under the kick-panel. There was a TSB that said the ground screw can come loose and cause electrical issues. I had the problem myself after about a year of ownership.
    Also check the electrical harness that runs under the driver-side headlight as others can chime in about the affects of a chafed harness.
    Good luck.
    Jul 2009
    I'm kinda thinkin' "ignition switch". All the signs are there of a faulty contact within the switch mechanism itself...best of luck!
    Vixer Fixer
    Mar 2012
    sold
    would an ignition switch cause it to die in the middle of the highway? if it would not have restarted i would have said timing belt broke, but if it restarted that cannot be the case
    i replaced about 5 sensors and the fuel pump about a year ago to try to fix my idle problem but its back again this week - im worried about this same thing happening to me
    im fixing it for good this time with a for sale sign
    best of luck hope its something easy and inexpensive
    I had a '69 Z28 that developed this same issue. Finally discovered that the tach wire had worn thru at the firewall. Every once in a while it would ground out and the engine would die, but start right back up.
    I think that looking for an electrical issue is the right place to start.
    Mar 2012
    sold
    i agree - unfortunately those are the biggest pita of them all!
    Jan 2010
    1999 Astral Silver
    Well even though I didn't see any corrosion i did file negative post and the connector and was able to drive 2.5 miles to my mechanic (timing belt due) I wish its that simple but will keep any eye on it.
    Thanks ya'll !
  2. Vx Engine
    Last Post: 02/21/2006, 03:53 AM
  3. Replies: 1
  5. Engine starts then shuts off
    By deldorado in forum VX Troubleshooting...
    Last Post: 05/07/2003, 01:08 PM
