Transmission went out:( Replace or Rebuild??
Transmission just went out and I'm not sure which is the better route to take. Specifically what its doing is this, reverse and low work fine. Drive, third & second slip practically like its in neutral.
This happened suddenly overnight, woke up the following morning and surprise. I always thought transmissions go out slowly, guess not.
A local shop quoted $1900 to rebuild the tranny. I can get one from a trooper shipped to a local salvage yard for $800 but then would still need to do the swap. Plus I remember someone on here mentioning rough gear changes after doing a trooper tranny swap? Anyone else have experience with that?
Third possible option is a replacement with a different tranny, is that even possible? I know a standard rather than auto has been done but any other automatic solutions?
Thanks
Keith
----Trans Siberian Orchestra
