Results 1 to 3 of 3
Thread: Little help with Yakima Load warrior basket
    Jul 2011
    1999 Silver VX
    Just need a little help with my Load warrior install??? If I center the front 2 mounts on the crossbar, the back one's are WAY off of center. I've seen many people have this basket mounted, but through reading endless threads, and voyerizing MANY galleries, noone I've found that show a close up of the mounting hardware. just Wondering if I'm missing something, or did those that have this basket just leave it off center. Sturdiness is a MUST as I'll be placing full size spare in here soon (hopefully)
    Thanx in advance. If you don't wanna type, and just wanna post pics thats fine by me
    2000, Ebony, VX, 0370
    Thanked: 12
    You should be able to move the mounts on the Load Warrior around a bit even though it doesn't look like it. You can put the mounts between any of the smaller tubes of the Load Warrior. The mounts on the Load Warrior don't exactly match up with the cross bars on the VX, but you can get them pretty close. I actually took my Load Warrior apart and cut a little bit out of the middle of it so that it fit the VX roof rack perfectly.
    Jul 2011
    1999 Silver VX
    I ended up trimming the mounts on the roof rack... just enough to move them away from each other a little bit... fits perfectly... thanx
  1. VX Lift At Warrior Automotive, Denver Colorado
    By VXRick in forum VX Modifications...
    Last Post: 02/22/2020, 07:26 AM
  2. Wasteland Weekend -Burning Man w/ Road Warrior Twist
    By wekilled in forum Chit-Chat ...
    Last Post: 09/30/2011, 05:34 PM
  3. Which load?
    By Toad80t in forum VX Talk...
    Last Post: 10/18/2008, 12:19 PM
  4. new custom brackets for a yakima load warrior
    By protonvxmatt in forum VX Modifications...
    Last Post: 04/04/2008, 06:07 PM
  5. Get a load of this...
    By Heraclid in forum VX Talk...
    Last Post: 06/13/2006, 08:12 PM
