As tom4bren said that ship has already sailed. I dont think you'll be getting any information by putting the belt and pulleys back on. In fact it may just make you more confused.
What I would do is: Align the crankshaft pulley as shown above and follow the links and videos as if your timing is lost. The belt didn't break while the engine is running but your timing is technically just as lost as if it had... Im guessing following the instructions and getting the camshaft pulleys to "spring" to the correct position will be about a 30 min. investment of your time. To put your pulleys back on only to take them off will probably take twice that and your not guaranteed you'll receive any information by doing it, so I wouldn't bother...
If you need pictures of where my camshafts sprung to to confirm your position is correct just say the word and I'll load them up!
We'll get that engine purring again!
