Results 1 to 13 of 13
Thread: Torsion bars
    Jan 2014
    2001, Foxfire, VX, 1132
    Torsion bars
    I did a search & didn't see what I was looking for. Does anyone know if the VX & Troopers have the same length torsion bars?
    01, LineX tan/black, 1055
    Jump on independent4x site. The trooper and VX have the same torsion bars. A few of us have the HD torsion bars, I love em.
    Jan 2014
    Thanks! I know when you look up OEM torsion bars they are different. But I thought the dimensions were the same. The reason I'm asking is for down the road. When I put the Cummins in it I'm afraid the stock torsion bars won't hold the extra 3-400lbs plus give me the lift I want. So I was thinking the Trooper ones would help since it's a heavier vehicle.
    Actually I "think" ours are stiffer...not 100% sure on that one though. The Indy4x hd would probably be a better bet. Or coilover
    Weight on 3.5l trooper and vx should be nearly identical in the front end.
    Jan 2014
    We'll after doing some poking around the internet, it looks like Troopers are 500-550 lbs heavier than a VX. So stock trooper bars or the Independant4x ones should probably give me what I'm looking for. Thanks for the advise!
    If you go with Indy, you'll need to order them 3-4 months in advance. They only have production runs a few times each year. They may have them in stock when you call but I'd hate to see your project put on hold if they're out.
    Oct 2003
    1995 Isuzu Trooper LS
    I doubt if Trooper torsion bars are much heavier than VX, if at all. The Trooper was sprung rather softly from the factory as a soccer mom vehicle, whereas the VX was more of a rally vehicle and probably had stiffer springs. I don't have any hard data to back this up, but that is my speculation.
    I would look at the aftermarket torsion bars, they are 20-30% stiffer than stock IIRC.
    Yeah, I would say go for the HD T-bars. Although the Trooper is heavier, even the anti-sway bars are not as stout as what is in the stock VX. My understanding is that the HD T-bars were developed to handle a winch & heavy bumper on Troopers so that is probably your best bet for your upcoming setup.
    PLUS!!! The HD torsion bars will give you 0.05% increase in throttle response.
    ^^^ABSOLUTELY!! .07% increase if your VX is yellow!
    0.09% If you're the type to go 'round droppin lightning bolts down peoples shorts.
    That extra weight in a trooper is overall, not in the front end. There is no real reason the front of a 3.5L trooper is any significant amount heavier than a VX. Same engine, same front suspension, maybe a little more front bumper and sheet metal, but other than that, notta. Go with the HD torsion bars, I guess I got lucky and they were in stock, got them right away! I love em.
  1. HD Torsion Bars: Independent4x.com
    Last Post: 04/10/2015, 11:24 AM
  2. Cranking torsion bars too much??
    By Boonetown123 in forum VX Troubleshooting...
    Last Post: 08/31/2014, 12:43 PM
  3. Cranking the torsion bars...
    By espidus in forum VX Modifications...
    Last Post: 04/12/2012, 10:09 PM
  4. HD Torsion Bars: Anyone tried them?
    Last Post: 02/01/2012, 10:14 AM
  5. Torsion Bars
    By joesvx in forum VX Modifications...
    Last Post: 10/24/2003, 07:54 AM
