Results 1 to 7 of 7
Thread: Cruise Control problem
    Oct 2013
    1999, Black, VX 1185
    Trying to track down a problem - 99 VX -When I turn the cruise on (Cruise Main button on dash) indicator on dash come on just fine. When I go to set the cruise at desired speed - will not set, and light on dash blink. Any ideas where to start?
    I'd check fuses first. The control could be on a different circuit than the sensor. Check the fuses in the cabin & in the engine bay.
    You may also want to find someone with a scan guage that you could borrow to see if the speed sensor is registering on the 'puter.
    Dec 2012
    1999 Silver VX 1613
    Did anyone find the fuse? Found my 1999 to have the same problem last night. Will be checking today.
    Rod
    Jan 2014
    2001, Foxfire, VX, 1132
    Since the set light flashes when you try & engage it, I doubt it's a fuse. Most likely it's the brake light switch. The switch has 2 contacts inside it. 1 for the brake lights, & the other for the cruise. Unplug the connector at the cruise servo. Pin #3 (wire color is brown with a red tracer) should be grounded when the brake pedal isn't pressed. When you push the brake pedal it should show no ground (or open circuit)
    If you don't know how to test for ground. You will need a test light. attach the clamp of the test light to the positive terminal of your battery. When you check the brown w/red wire the test light should light up when the pedal isn't pushed & it should go out when you push the pedal.
    Jan 2014
    Just wondering if you figured it out??
    Apr 2014
    2001, yellow, vx,0838
    Did you fix this issue?
    That others may Live
    Warrior Automotive
    Jake
    Jan 2014
    Hello???
  1. Cruise control light stays on
    By Bantan in forum VX Troubleshooting...
    Last Post: 03/04/2013, 11:45 AM
  2. Cruise control on a JDM
    By AussieVX in forum Japanese Domestic Model (JDM) VXs
    Last Post: 05/02/2009, 12:52 AM
  3. cruise control
    By dynofan in forum VX Troubleshooting...
    Last Post: 05/15/2006, 08:06 PM
  4. Cruise Control issues
    Last Post: 02/09/2006, 02:53 PM
  5. SC Cruise Control Bracket and Cable installation
    By frankie100 in forum VX Modifications...
    Last Post: 10/25/2004, 06:21 AM
