Results 1 to 4 of 4
Thread: 98 Trooper
    2001, Dragon Green, 1342
    98 Trooper
    so, sitting here, looking at Craigslist and someone is parting out a 98 Trooper. I wonder what parts I could get that would be worth hanging onto.
    Any suggestions?
    Nov 2012
    Depends if it's a manual or automatic. Drivetrain is virtually the same except for the front axle disconnect. Fuel delivery is the same. If it's an auto all the TOD stuff is the same as a VX. Get the rear door and fog light switches and switch panel to replace cubby hole if desired. If it's a 5 spd get the tranny, clutch master, slave, and hydro line along with the ECU and fuel line. Even if you don't want the 5 spd someone else will.
    There's no 'I' in denial.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    And don't forget the flywheel, the hard fuel lines, and the exhaust manifold.
    Check the diff ratios too...
    ...probably 4.56..BUT..ya never know,it might have had a 4.77 swap.
    Jo
  1. Will a Trooper ECU work??
    By Ebenezr in forum VX Talk...
    Last Post: 08/26/2011, 12:02 PM
  2. 93 Trooper RS for wife
    Last Post: 08/23/2011, 06:18 PM
  3. 89 Trooper RS
    By Hide in forum VX Talk...
    Last Post: 11/12/2010, 04:25 AM
  4. TROOPER vs VEHICROSS
    By jacobus in forum VX Talk...
    Last Post: 09/24/2005, 07:07 PM
  5. Trooper CV=VX CV?
    Last Post: 06/25/2005, 10:20 PM
