front brake caliper test question
Okay, didn't pay close enough attention. Reinstalling front brake caliper. The 2 slide bolts are different, and sure enough, the manual says a difference. one is called a lock bolt (bottom) and the top is called a guide bolt. There is a difference between them. One looks like a regular bolt if you like with flats on the shaft, but the other has a different end, like a rubber tip. anyone know which is which
