Results 1 to 7 of 7
Thread: Moab To Do List Keeps Getting Longer...
    Nov 2012
    Well here's my list so far:
    Done:
    HD tie rods
    CV boots replaced
    HD torsion bars
    CB and antenna installed
    Modify cargo basket to install under roof crossbars instead of on top of them
    Steering stabilizer
    HD lower links
    To Do:
    4.56 3rd members with rear locker
    Wheel bearings (front at least) I think I'll just pay someone to do these
    Re-install big rims and tires (took them off for winter)
    Tune CB antenna
    4 wheel alignment
    Install rock sliders from Sue at the Stoop
    Agh...
    During and after Moab:
    Fix all the stuff I break
    One day at a time, one day at a time.
    There's no 'I' in denial.
    Yeah, I remember doing my lift only a couple days before leaving for Moab in 2008. Man, I wish I was going this year.
    Yea....
    I remember doing diff changes two days before leaving for Moab.
    "Leaving".. being the key word... 90 miles into trip .. BOOM.
    ROAD TEST SCOTT..thats all I have to say about this
    Jo
    Nov 2012
    Progress!
    I went out yesterday and rented a stall in a DIY garage here in Denver. Not a bad deal, I payed $35 for an hour in a stall that includes a lift and all the tools including air tools you need. Well worth it especially considering it was snowing and my garage is not heated. HD lower links installed in about an hour. The only issue I have is the location of the grease fittings. If I put them on top then they looked like they would break off when suspension is fully compressed so I have them on the bottom. I will definitely break these off the first time they see a rock so I'm going to replace the zerks with flush mount fittings. Question for those that have done this upgrade: Did the width of the bolt sleeve, for lack of a better term, cause the brackets to pinch in slightly?
    Nov 2012
    I also remounted my roof basket under the crossbars. I had to cut off four of the vertical basket supports but got everything to fit nicely. This ended up lowering the basket about 2 1/4 inches. The problem with this setup is it isn't as strong as having the basket rest on the crossbars though. I am going it reinforce each place were the basket and crossbars meet using some paracord.
    1999, Ebony Black, VX, 1614
    Thats a pretty cool idea. I wonder if there is anything similar out here in the West Chester / Cincinnati OHIO area.
    Nice touch with the basket... No need to height compensate just because you're around me.
  1. My MOAB '07 Prep List
    By Kenny in forum Moab 'Zu Zoo X May 9-12, 2007
    Last Post: 05/06/2007, 08:42 PM
  2. Alarm Horn - No Longer Available
    Last Post: 02/25/2006, 10:45 PM
  3. The who's going to Moab 05 list
    By Triathlete in forum Moab 'Zu Zoo VIII May 18-21, 2005
    Last Post: 05/12/2005, 08:15 AM
  4. Prep list for Moab
    By Moncha in forum Moab 'Zu Zoo VIII May 18-21, 2005
    Last Post: 04/17/2005, 12:04 AM
  5. MOAB Prep list...
    By Tone in forum Moab 'Zu Zoo VI May 14-17, 2003
    Last Post: 04/29/2003, 10:49 PM
