Results 1 to 15 of 20
Thread: window stopped working
    Jan 2010
    2001 black 1145
    Passsenger window was working fine (widening of window track done years ago) and today won't work. Hear a clicking sound coming from passenger door when window switch is pushed up or down, either on drivers switch or on passenger switch. Any thoughts? Regulator?
    Quote Originally Posted by Daly View Post
    Regulator?
    since it's clicking ... probably.
    I posted there was a Passenger regulator on ebay, about a month ago or so....but it finally sold.
    http://www.vehicross.info/forums/sho...ight=regulator
    Here's a BRAND NEW one...a bit pricey since it's at ALL Hyundai/Kia in California...but it's available, depends on how bad you want it I guess.
    http://www.ebay.com/itm/1999-2000-20...3881e8&vxp=mtr
    Actually, it could be a bad relay. See if you can hear where the clicking is coming from. If the clicking is coming from the kickpanel, there's a chance it's just the relay. I don't know if you can take it apart & clean it or if you need to source a new one.
    Jan 2010
    2001 black 1145
    Thanks will check out relay first.
    Jan 2010
    2001 black 1145
    window
    Clicking is coming right from around the switch/door handle area.
    That means your relay is functioning so it's probably your regulator.
    Nov 2012
    I've had luck with other cars doing this:
    Remove door panel and while activating the window up/down switch back and forth tap the motor with a small hammer. If the gears are bound this can jar them loose. It's worth a try.
    There's no 'I' in denial.
    2001, Dragon Green, 1342
    you motors bad
    just went through the same thing. R&R the motor. you want a Cardone 47-4307. Don't let them sell you a 4309, its a different drive gear even though it says it fit, it don't.
    Jan 2010
    2001 black 1145
    Never taken off door panel before. Steps to remove
    take off handle, disconnect window and lock switch, remove screw for door opener, pop off plastic tabs holding door panel on
    anything else?
    Remove tweeter cover (1 screw behind little disc), door handle cover (1 screw), window control panel (pops up & forward I think).
    Pull door panel away from door (IIRC, there's about 8 of those clips to pull free). Harbor Freight sells a pretty slick tool for releasing those clips without breaking them.
    Lift door panel up away from window track & release connectors for window & lock wiring from behind panel. Set door panel aside.
    Gently release vapor barrier from door. It's glued all the way around. You'll probably tear it but it can be patched with duct or masking tape. If you tear it real bad, you can replace it with a large (heavy duty) trash bag.
    I'm going from months old memory so someone chime in if'n I've forgotten anything.
    something I wrote a few years back. I had the tools, but if you don't just adapt what you have even if its from the kitchen. You might want to pick up some plastic trees if you break any or they are bad.
    http://vehicross.info/modules.php?na...warticle&id=22
    Here ya go. I made a convenient pdf out of your How2. I took a few liberties with editing to add a few of my own comments (I hope you don't mind).
    Cool. Could you also change a bobo. Meant to say #3 phillips, not a 2 when removing the 2 screws under the door handle.
    bobo fixdeded
  1. Speedometer Stopped Working...??!
    By TheUltimateMan in forum VX Troubleshooting...
    Last Post: 05/24/2011, 08:30 AM
  2. Stopped at a red light....looked down and saw
    By JAMAS in forum VX Talk...
    Last Post: 10/12/2009, 07:40 AM
  3. Engine dying while stopped?
    By JAFO in forum VX Troubleshooting...
    Last Post: 11/04/2004, 06:29 AM
  4. Light's ON Warning Buzzer Stopped Working
    By Navigator in forum VX Troubleshooting...
    Last Post: 03/15/2004, 06:52 AM
  5. A/C stopped working???
    By Edward in forum VX Troubleshooting...
    Last Post: 03/03/2004, 10:59 PM
