Quote Originally Posted by Vinnybin View Post
So Im putting together the vacuum hoses and what my labels say(where they came from) is different than what the sticker under the hood says they go. Im sure I wouldn't have mislabeled them but... should I put them back the way the sticker says? Also the little ones look like they are holding a seal but they also don't use any clamps to hold them tight. Should I replace with fresh ones?
Sorry, just saw this. If it wasn't fouling up the engine (CEL), I'd put them back the way you took them off.
The smaller ones should be fine. Good thing about them is that they are easy to reach, so if you want/need to replace them, it isn't difficult.
