Cruising around the other day, I realized my horn does not work. When I go to press my wheel, it does not event seem as if there is a horn as the center unit does not depress. The thumb horn area also has very low resistance to pushing. As in it does not feel like it has enough resistance to have a horn in there, feels more like a really dense pillow. Does it seem that my wheel/horn depression is broken or that most likely it would work if the sound producer was working. Could be a fuse with a stuck wheel based on threads from the past, but not sure how I would best diagnose this. I definitely would upgrade if anyone has any air kits that mount well in the VX that are loud/deepish they want to recommend.If OEM is the best way then I would like to purchase an OEM horn and whatever connections to it you have (just in case).
