Results 1 to 10 of 10
Thread: Grinding while turning with body roll
    2000 IronMan #11
    So I am getting a grinding noise as the title says while turning and it is louder while there is a little body roll into the turn.
    - What is this? - Bearing?
    - I have just recently installed the surtrak axles
    2000 IronMan #11
    specifically the driver side when turning right
    2001, Dragon Green, 1342
    Do you feel it or hear it and if feel it, then in the steering wheel, console, or seat of the pants
    01, LineX tan/black, 1055
    It does sound like wheel bearings.
    You can check the front wheel bearings pretty easily. Jack up front wheel and try moving it top to bottom. If you have any play bearings are bad or preload needs adjusted.
    Apr 2014
    1999 Dragon Green Mica VX
    Where would one purchase wheel bearings+ pinion bearings (inner and outer)+ seals?
    2000 IronMan #11
    Of course my mechanic could not replicate the noises. So he returned it.
    He did think that maybe my tire(s) have started to rub? Had them on for 2+ years now.
    Sep 2011
    1999, silver, 0457
    I am actually going to be replacing my CV shafts soon, mechanic said they will need to be replaced. He said I will know if it goes bad because it will be a noticeable grinding noise. We noticed they were going bad while repacking the bearing. We will also be replacing bearing at the same time. So maybe have him check your CV shaft.
    Here is a thread I started about replacing them:
    http://vehicross.info/forums/showthr...threadid=25616
    2000 IronMan #11
    I just replaced them with surtracks less than a year ago
    Sep 2011
    1999, silver, 0457
    oh sorry I missed that from above
  1. horrible grinding when turning
    Last Post: 03/14/2015, 07:48 PM
  2. grinding/rubbing sound when turning...need help! please please!
    By Hcloud13 in forum VX Troubleshooting...
    Last Post: 12/23/2013, 12:32 PM
  3. grinding sound, like worn pads grinding on rotor but now
    Last Post: 05/15/2013, 12:45 PM
  4. grinding while turning
    Last Post: 02/07/2007, 08:25 PM
  5. Skreeeeech, when turning...
    By Navigator in forum VX Troubleshooting...
    Last Post: 10/06/2005, 09:47 PM
