Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Front drive shaft help
  1. #16
    AGREE 100% Mark...
    I know others have warned not to use these off road, but I would argue that they are fine for moderate wheeling and are perfectly fine for on-road use.
    True...they are NOT as strong as OEM....
    But..having used them for both road, moderate and hard core wheeling..
    .... you sum it up perfectly Mark
    The tolerances for ball fit in green cup are spot on..
    ..as is spline fit and axle shaft diam.
    If its Only for ON road use I would recommend these 100%.
    If you wheel off road.... trails and bumps are fine..
    ...just dont rock crawl with them.
    Jo
    Sep 2011
    1999, silver, 0457
    sounds good! thanks for the help everyone
  3. #18
    2001, Ebony Black, 1153
    Those are the exact half shafts that I bought and installed a few weeks ago. I haven't had an issue with them at all and they have been to, and through, Moab. I know others have warned not to use these off road, but I would argue that they are fine for moderate wheeling and are perfectly fine for on-road use.
    Agreed, however there are far more factors then just road conditions. Driving style, weight of wheels and tires, among others. Fact is aftermarket is not as good. I am sure they will work for many people perfectly fine. But for the money I would get used OEM.
  1. Front drive shaft
    Last Post: 02/17/2017, 06:02 PM
  2. front drive shaft
    Last Post: 02/01/2015, 11:41 AM
  3. Front drive shaft in 2WD.
    By Dumke in forum VX Talk...
    Last Post: 05/02/2013, 05:16 PM
  4. Drive Shaft Rebuilding
    By blacksambo in forum VX Troubleshooting...
    Last Post: 12/03/2011, 10:27 PM
  5. Dropping front drive shaft
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 06/04/2004, 12:25 PM
