Ill delete this thread after I get a quick answer since there is so much on this already.
After reading most of the CV axle problems I am just more confused then ever. I accidentally bought 3 axles from sure track. One without the green cup and both sides with it. The one without was when I was not going to replace the green cup and the other two were back ups.
The sound is clicking when power is applied. Lots of loud clicking and I don't think one or both my from wheels are turning anymore. Pretty sure its the driver side. This means that I am replacing the green cup because of the grooves that were made. Is this correct? The drivers green cup is scorned and wavy. I can see from the outside where is been worn in and gotten real hot. I have the entire shaft assembled and ready to go in. How do I get this thing apart? A quick list should get me on the right track or referral to a link with what I need to do would be very helpful.
