can't help ith the location
Originally Posted by
jarvis
I have a Q ? are VXs factory equipped with an alarm system ? if so anyone know where the siren is ...my fob works ...churps too ...and light inside looks like its armed ...but trying to open it or bumping it does not set anything off...just wondering if someone disabled part of it ...and if there is a valet switch...would like to re inable it if......
but it does have a factory alarm. Try the manual. If you want to see if it works arm it and use your key to unlock and open the door without using the FOB. Should set the alarm off it does to me.
Carter Pewterschmidt
