Results 1 to 15 of 18
Thread: I noticed my power steering fluid leak...
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    ...was getting worse. I've had it since I've had the truck, but it has just required filling every 6 months or so. It's been a slow and steady loss of fluid. Last weekend, we changed the upper and lower ball joints on both sides, and the inner and outer boots on both sides, as well. As this is a messy job, when finished, I sprayed under the truck w/a high pressure water hose. The next day, when leaving work, I noticed a puddle on the ground in front of the truck. It had bled out all the p.s. fluid. So I topped it off, and it lasted for a few days, but it was almost empty again yesterday. This morning I finally decided to ascertain where the issue was so I could fix it. I spent the better part of 4 hours tracking down the leak. I had mentioned @ one of the VX meet ups this spring that I was going to replace the rack, as I thought that's where the leak was coming from. I was also anticipated a bad gear box or pump, but those were ruled out as the leak was coming from somewhere near the radiator. Turns out it's a hose, which is a good thing in the grand scheme of things.
    This is where it gets awesome. In order to get to the hose, I had to remove the radiator and the radiator fan.....which I had to remove a few weeks ago when the radiator sprung a leak. I hate, hate, hate having to do things twice, as it is a colossal waste of time.
    Ordered the hose, it'll be here sometime this week. It's a pain to remove it, as it attaches to the pump. I'm planning on completing the removal before the new part arrives.
    The hoses are notorious for leaks. Most ps leaks have been the hose. They are a pain in the rear to change...about a 4 hour job. I have read it helps if you access through the wheel well. This is on my to do list. It is also better to change them sooner rather than later...The fluid destroys bushings when it leaks on them...ask me how I know. Upper and lower control arm bushings and sway bar bushings are also on that list...Once it cools down a bit here.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Yeah, I was trying to figure out how to pull the hose out pump-side, I had to look through the wheel well, as it isn't really accessible from the top or bottom. The wheel well flaps look promising.
    While I was looking for the replacement hose, I can see how it connects to the pump, so yeah, it'll have to be detached through the wheel well, then pulled up through the top. I'm replacing this one:
    http://www.amazon.com/Edelmann-80368...dp/B001NYMEB0/
    So far, I've had to pull off the air box assembly, the radiator and fan. This looks like that'll be all that has to come off. Once this is done, the only other leaks I'll have are from the intake manifold gaskets, which are sitting in the garage, and then all the maintenance will be done
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    The hose came in yesterday, so I went ahead and replaced it. The bolt that holds the hose onto the pump can't be removed from the tire well, as you can't really turn the 24mm wrench as it hits the interior wheel well.
    To take off the hose, you really need two 24mm (or 15/16") wrenches, one to hold the piece that the hoses attaches to, and the other to remove the bolt.
    See that gasket? If you remove the bracket that the top hose attaches to, you have to replace it. There's a PS pump gasket kit you can get from Autozone for $17.99, OR you can pick up a gasket pack from O'Reilly's that has 18 different-sized gaskets for $7.99. The package advertises that they are made of Viton, and are safe to come in constant contact w/fuel. So, that means PS fluid will be no problem. Unfortunately, after I hooked up that line the first time round, I didn't replace that gasket. I filled up the reservoir partially to check for leaks, and of course it leaked. That required taking the hose off again, which is a pain b/c the bottom 12mm is a *PAIN* to get off, as the new hose loops over the top of it. This took a lot longer than I thought it would.
    The only thing I need to replace now are the valve cover gaskets, and the truck will finally be leak free.
    May 2007
    1999 Black Rodeo
    I would much rather fix your leak then the one I had. Here is what needs to be done to replace a leaking steering rack on a Rodeo. 12 hours over 2 days (stupid rain).
    --Dave
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Quote Originally Posted by Gizmo42 View Post
    Damn, man, that's a mess. It took me about the same amount of time to track down and fix my mess, as well. But, I didn't have to tear all *that* apart. I was worried that I had a jacked up rack, as well; suffice it to say I felt quite a bit of relief when I determined it was just a hose.
    May 2007
    1999 Black Rodeo
    Lucky for you VXs dont have R&P steering. They have a good old steering box. Should be MUCH easier to replace if ever needed.
    Oct 2003
    1995 Isuzu Trooper LS
    Well I'm about to find out...got sick of the free play in my steering box and ordered a reman from Rockauto today.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Did you already try to tighten it? I did this, too, and it has helped to clean up some of the slop. I'm making incremental adjustments to get it where I like it.
    http://vehicross.info/forums/showthread.php?t=5774
    Oct 2003
    Yeah I messed around with that some, but never was satisfied. I'm just going to replace it and be done with it.
    Can anyone tell me whether to use Power steering fluid or ATF in my, about to be replaced, steering gear (that I just purchased from RockAuto..great customer service there)?
    Scott
    2001, Dragon Green, 1342
    so, did this hose work? and is this the one that always leaks?? don`t know what you paid for it, but Amazon has it on sale right now for $39.70, list for $129.34.
    Quote Originally Posted by ScottinMA View Post
    Scott,
    The shop manual on page 0B-4 says 'power steering fluid' but on page 0B-7 says DEXRON-III Automatic Transmission Fluid. I'm guessing you should go with ATF.
    Thanks Tom, I saw that conflict as well and wondered whether there was a definitive answer to this. As someone wrote, I know my mechanic topped it off with power steering fluid and following that the leak really got worse. Don't know whether it's just coincidence or the OEM fluid is ATF and putting the PS fluid makes it worse. I just want to do this right when I change out the steering gear.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    I paid $37.65 for it on eBay, and yes, it resolved my issue.
  1. Power steering fluid leak!
    By jdm monkey in forum VX Troubleshooting...
    Last Post: 10/19/2012, 07:52 AM
  2. Leaking Power Steering Fluid
    Last Post: 11/10/2008, 06:50 AM
  3. Power Steering leak
    By Dino in forum VX Troubleshooting...
    Last Post: 10/25/2007, 04:43 PM
  4. Power Steering Fluid
    Last Post: 09/05/2006, 11:02 AM
  5. Brake Fluid vs. Power Steering Fluid
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 07/01/2006, 04:12 PM
