Results 1 to 6 of 6
Thread: P/S Hose routing through the gear box
    Mar 2012
    1999 Ebony Black (Runs great/Looks a lil less than great... but getting there!)
    Is someone able to simply go outside and shoot me a pic of their P/S gear box so I know what lines to connect to which port? I have
    A newly installed gear box
    New pressure line(s)
    New pump installed with the pressure line on IT but no lines ON THE BOX. I want to make sure the one from the reservoir gets hooked up right and the one from the pump gets hooked up right.
    No.. Pics from the service manual SHOWING ME EXPLODED PUMP AND GEAR BOX ARE NOT HELPFUL only a color pic of an actually hooked up and working system will do.
    With mucho thankos,
    Sindarin
    Always Forward,
    The Down to Earth Nurse
    Oct 2007
    2000 Victory White Ironman
    the pump to reservoir should be a bigger line and connects to left side res. if looking directly at it. the other smaller line goes from the res. to the gear box. front closest to wheel well. hope that helps
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    In addition, in looking at the reservoir from the front of the truck:
    a) the hose from the back (closest to the firewall) of the reservoir goes to the top of the pump and
    b) the other hose is connected to the gearbox.
    Mar 2012
    To WHICH gearbox connection, sir. (Closest to firewall or closest to radiator...) THATS what I am missing. It ain't the PUMP or the RESERVOIR foiling me, the gear box has two plastic retainers in it. One close to radiator, one close to firewall.
    Appreciate the input, and I never met a Texan I didnt like (but they treat them like **** here in Colorado for some silly reason)
    Quote Originally Posted by sindarin View Post
    They are close together...the line from the reservoir goes into the opening closest to the firewall and nearest to the inner fender. Also closest to the flex joint in the steering shaft.
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    +1. The one on the back right.
  1. Need some help on wire routing
    By mantis465 in forum VX Troubleshooting...
    Last Post: 06/04/2016, 01:21 AM
  2. Steering Gear box Hose
    By Jonnie in forum VX Troubleshooting...
    Last Post: 09/10/2011, 02:29 PM
  3. 4400 RPM "LAG" in third gear 3rd Gear
    By Ikkesh in forum VX Troubleshooting...
    Last Post: 04/15/2009, 06:13 PM
  4. auxilliary drive belt routing
    By mad1230_10 in forum VX Troubleshooting...
    Last Post: 09/15/2005, 09:01 AM
  5. Breather hose?
    By thedutchguy in forum VX Troubleshooting...
    Last Post: 06/25/2004, 11:55 PM
