Results 1 to 5 of 5
Thread: check TOD light
    Jul 2014
    2000 white wizard 2199
    check TOD light
    Hi, I am intermittantly getting the check TOD light flashing. I have checked the diagnostic codes and have got the usual code 12 plus a code that I think is 5 long flashes which i take to meen code 50. Can anyone help me with what this code means?
    http://www.vehicross.info/forums/sho...22TOD+codes%22
    Post #15 has the .pdf for the codes...no 50 listed.
    Jul 2014
    Thanks for that. I have rechecked the flash codes and now think the '5' flashes could be code 55 but that code doesn't relate to anything I can find to do with the TOD either. Any thoughts or suggestions would be much appreciated as I am at a dead end as to what the problem could be.
    Oct 2014
    2001 Yellow 1450
    I am new to the forum and new to my VX. Ran great for 2,000 miles. Just now getting a flashing CHECK like on the TOD. Had you or anybody advised of the issue and likely solution?
    Oct 2009
    2001 Mica Green VCS 0403
    Check tire pressures to be certain they are all the same. Also check tire wear.
  1. tod check light
    Last Post: 11/10/2016, 04:16 PM
  2. check light and abs
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 05/28/2013, 05:23 AM
  3. TOD Check Light
    By saberwolf in forum VX Troubleshooting...
    Last Post: 12/28/2008, 10:48 PM
  4. Tod Check Light Help!!!
    By ron in forum VX Troubleshooting...
    Last Post: 07/02/2007, 11:56 PM
  5. CHECK TOD light :(
    By V12BMW in forum VX Talk...
    Last Post: 01/17/2005, 10:03 PM
