Results 1 to 10 of 10
Thread: Checking Trans fluid
    Jul 2014
    2001 Pearl White Vehicross 1455
    Question Checking Trans fluid
    I've read all of the threads I could on how to check trans fluid so I'm pretty sure I'm doing this right.
    1) Car is on level ground
    2) Start car and with foot on brake run through all the gears and back to neutral.
    3) Car is idling in neutral when I climb under to remove the fill plug.
    3) Then I remove the fill plug (not the drainplug ) and about a cup of fluid came out then fluid continues to "weap" and drip as the engine continues to idle. Does that mean I'm now at the right level? Was the trans over filled?
    I've been chasing down a trans fluid leak and there's been a decent puddle on the garage floor (about 3" in diameter) after I drive it. (It's dripping from puddling in the cross member so I know there's more in there as well). It just seems like it should have lost a lot more fluid over the past couple of weeks and I expected it to be low. I didn't expect anything to come out when I opened the fill plug.
    Any body have any ideas?
    Wrench
    Was it at the correct temp when you checked it?
    It's possible the last person to lay wrenches upon it, overfilled it...
    That's all I've got.
    Jul 2014
    Temp was a guess. It sat for about 2 hours since I last drove it. I was able to handle everything with rubber gloves on so it wasn't too hot. I guess my real question is, if the trans is in park and the engine is in idle will fluid continue to drip out just due to circulation? I would assume so.
    Current caretaker of The elusive 2001 "Pearl White" VX - The last one.
    1988 BMW 325ic
    2001, Ebony Black, 1153
    I would let the fluid cool overnight and try it again soon. Temperature gauge is cheaper then a new tranny :-)
    Dec 2012
    1999 Silver VX 1613
    Shouldn't the temperature be at operating range when checking? All the cars with dipsticks say right on the stick to only check when "HOT".
    Rod
    Jul 2014
    The specification in the service manual says to make sure the coolant is between 90 and 135 degrees.
    Remember that the TOD uses trans fluid as well, so you might check your seals and gaskets on that fine piece of the puzzle...
    Wrench
    I use my hand on the pan trick. If I can leave my hand on it for 3-5 seconds without having to remove it from contact, the temp is about right. Any warmer or cooler is no bueno..
    Dec 2012
    1999 Silver VX 1613
    Thanks for the clarification. Going to change my fluid in the next few weeks. Any suggestions on what type to put in? Had it changed at a transmission shop two years ago and they recommended annual changes. I tried to schedule an appointment this winter while in the area but couldn't find a time when I had a day off and they had a hoist free. It was a 75 mile round trip so I wanted to be able to wait for them to do the service.
    Rod
    Wrench
    IMO, if you're using a good brand of synthetic ATF (Amsoil in my case) annual flushes are not necessary. If ya wanna drop the pan & change the filter every year or two, topping it up with some fresh juice, that's prolly still a little overkill, but is good for peace of mind.
    If using Amsoil S-S, I usually go 60-80k between flushes.
    But that's just one mans opinion...
  1. Trans fluid??
    Last Post: 05/05/2014, 01:39 PM
  2. Keep watch on your trans fluid. a lesson learned.
    By Ebenezr in forum VX Talk...
    Last Post: 05/23/2012, 02:03 PM
  3. checking the trans fluid
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 12/06/2007, 12:16 PM
  4. Trans fluid change - caution
    By marcosv6 in forum General Tips...
    Last Post: 04/04/2007, 08:36 PM
  5. change trans fluid?
    By zadam123 in forum VX Talk...
    Last Post: 11/03/2004, 02:53 PM
