Just curious to see how many installed diff drops to save their CVs, and if you get ducky, roll under the truck with a flashlight and see if your internal cuffs are torn, and if the flange shows any sign of rubbing on the prop shaft.
Yes
No
I want to
Never gonna happen
5 years and counting with diff drop.
NO cuff issues... YET!
Jo
Did you look with a flashlight? I gotta see how much my diff dropped, mine was torn for years with no issues, as I said, until the soup bowl at uwharrie got water and mud in it, then it was a losing battle.
No diff drop but 1 destroyed joint on my prop shaft. Since has been replaced with a low mileage trooper shaft...no issues.
I have a 2" drop and the boot/cuff ripped on the driveshaft years ago. Never had any issues with it and I would just add grease periodically to keep it lubricated.
2" is the max drop you can have before hitting the lower control arm... from what I've read, most other drops here are 1.5"
The ones we used to get from Welder Guy are 2". The ones sold by Joe Darlington are 1.5".
I've had no issues from mine since I dropped ... so we'll be doing Boy's Ebony as soon as we lift it (assuming I ever get the engine put back together).
There are lot more dropped diffs than I thought!
I wonder if Joe Darlington fabbed them all ?
Haven't done mine yet. If I get the extra control arms modified I got off of a trooper. I'm going to have the diff brackets dropped 3" & rotate the pinion about .5" to help the driveshaft angle. If I don't do the control arms I'll just do the normal 1.5-2" drop on the diff brackets.
I've got my new VX in the shop now - just got it and had the transfer case replaced, cv axle, added the 3" OME lift, 33" tires and they are trimming the cladding as we speak.
http://www.raceland.rocks/images/intheair.jpg
Wish it was this high on the ground - seems I need a body lift now...
Anyway, you have 2 VXs - father-son? I just posted last night that I bought my second by accident because of this forum :0) Actually the one posted by jnolan with the seized motor, so now I have a father son project for his 16th Bday coming up in Jan.
Again thanks to jnolan for one heck of a deal on a his VX.
~UrbanTerror Thanks You
I got your jeep thing...now it hurts when I pee!
