Results 1 to 5 of 5
Thread: window regulator solution
    Did anyone capture the correct link for the window regulator repair posted years ago that resolved, once and for all, the binding problem we all experience. I've been searching the forum for two days and haven't discovered it yet and wondered whether anyone on here may have made a note of it.
    Scott
    I don't beleive there's been an "end all" fix to window binding. Many claims with different results.
    I ended up moving the window track forward (worked for me) but I've also seen the use of brackets, bungy cords & silicone. Obetome is working on a system with roller bearings around the center track... seems like a good solution.
    Wow, I thought this was resolved. No wonder I couldn't find "it".
    Aug 2014
    2000 Proton
    Thanks for the info. very helpful
    Quote Originally Posted by ScottinMA View Post
    Aug 2014
    00YellowVX0788
    You moved both tracks forward (towards engine)? 1/4"? Bearing stops the widow from falling forward but still drag when weather is cold.
  1. Window regulator fix.
    By dallas121469 in forum VX Troubleshooting...
    Last Post: 04/18/2017, 09:32 PM
  2. Window Regulator
    By tomdietrying in forum VX Talk...
    Last Post: 04/06/2015, 07:04 PM
  3. Replies: 1
    Last Post: 01/11/2012, 01:45 PM
  4. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 10:31 AM
  5. Window regulator TLC
    By WyldWeasel in forum General Tips...
    Last Post: 04/27/2006, 12:38 PM
