Hi guys i havent been here for a while and hope i can still get some answers here My vx heat is giving me a issue. here are the issues
1 when i put the heat on it isn't really hot, id say warm and takes a while
2 when the heat is on the windows fog up really fast and then when i put the defrost on it unfogs the windows but is really cold so i put the heat back on and windows fog up pretty quick.
it seams when the switch for recirculate is set it is hotter than when its in the middle or on fresh air.
I had my heater core changed a few years back when my car overheated and radiator changed as well. also i had a new clutch fan installed. the car doesnt overheat and runs at normal temp and am not really loosing antifreeze.
could it be a bad heater core again??
any ideas its sterting to get really cold outside
thanks
