Originally Posted by
Jay Dunford
I've been thinking about putting a Trooper auto transmission transfer case with the teralows in it in the VX. Anyone know if the driveshafts will line up with the Trooper case?
Yep. You'll have to change the front prop shaft to the u-joint Trooper one and swap the flange on the front diff to match it. For the rear depending on the year of Trooper TC the flange on the TC itself needs to be swapped to mate to our drive shaft. The TC is I think a little shorter but so the drive shaft extends far enough with plenty of spline still inserted. I've got my new gear set ready to go in, just need to find the time to do it.
There's no 'I' in denial.
