Results 1 to 5 of 5
Thread: VW antenna
    2001, Dragon Green, 1342
    VW antenna
    I know some of you have replaced your antenna twig with one off of a VW Jetta I think it was. Could the whole thing, base and antenna be used? The rubber seal on mine is shot and needs replacing. If I can use the whole VW unit, then a new seal can be had from new.
    I did a search on Amazon and got a OEM looking antenna for about $15. My old one had a rotted base as well.
    -Wekilled
    douglaswekell(at)gmail.com
    Duh, on order
    so, are you able to enjoy your assignment any this time? Sure your wife and family are.
    Imagine with Putin's posture and our Administration, things might be,..a,...
    tense
    as my era was
    hope you have enough old hats around that remembered the games.
    Machs gut
    I have no personal experience, but a search of the site returns several posts claiming the stock VX antenna is a powered unit, and running non-powered (i.e. aftermarket stereo) results in poor reception. The VW "Fuba" antenna is supposed to be powered, but I don't know if wiring is the same.
    Gregg
    2001 Proton Yellow #1379
    Jun 2007
    2001, Proton
    I can not be sure
    But I doubt the antennae is a powered unit. I have unscrewed it while running the VX through the car wash which would be bad if powered and have not had any issues.
    Carter Pewterschmidt
  1. New low profile antenna
    By Makocross in forum VX Talk...
    Last Post: 10/14/2014, 11:23 AM
  2. Antenna question
    By AndyC in forum VX Troubleshooting...
    Last Post: 07/26/2011, 06:43 AM
  3. New CB Antenna
    Last Post: 02/13/2010, 12:07 PM
  4. CB Antenna
    By tomdietrying in forum VX Talk...
    Last Post: 02/09/2009, 09:59 AM
  5. i need a new antenna
    By autox-racer in forum VX Talk...
    Last Post: 10/01/2002, 04:25 PM
