Thanks for the tip. I might have to give the catch can a try.
OMG Tom, you just had to go there again, din't you (yup' I said DIN'T)! We all know yer catch-can can't possibly work, don't weeeee!!
Vixer Fixer
 Super VXer
						Super VXer
						Now you done opent up that can o worms. For shame!!! I was trying to save the NEWBs a ration of grief by not making them read that whole thread.
All I know is what I know & nut'n else. I was losing twice as much oil before than I am now (& I got an extra 0.05% increase in throttle response as a bonus). That's all I got to say 'bout that.
 Super VXer
						Super VXer
						I had an oil leak that was hard to track, and it too is a very long depressing thread. BUT it was near where you are describing. Anywho, behind the timing belt cover, there are the pullys that drive the cams. Where the cam comes out the front of the head, there is a seal. When I had some work done on my truck, that seal was replaced with a non OEM seal, and it became unseated and leaked down the front of the engine on the driver side, behind the cover. Now, oil can get to funny places with wind, spinning parts, ect, but there may be a chance that the oil could get from the cam, go behind the timing belt cover, and drip around the AC compressor
Like above, it's not a GOO suggestion, but a suggestion none the less! Oil leaks are really frustrating. They also make a UV ADDITIVE that can be added to the oil, and then driven, then when exposed to black light or the expensive uv flashlight they want you to buy, you can track where the oil is coming from
GOOD LUCK
