Results 1 to 8 of 8
Thread: Door Window Squeegee Question
    Jun 2010
    99, Silver, 1784
    Friends,
    I'm having some paint work done while the VX is in the shop. They're very thorough and want to envelop the exterior of the doors with paint. Which means taking off the squeegee or whatever it's called at the slice in the door where the window lives.
    Pic attached for clarity purposes (stolen from an old post by Tom - thanks bud!).
    Shop wants to know how this piece is attached so they don't damage during removal. It is double sided tape? Fastened from the inside (they haven't taken the panel off yet)?
    Just shout it out if you know.
    Thanks,
    -V
    -VI VX VNIVERSVM VIVVS VICI-
    Nov 2012
    It's been awhile but I seem to remember there being clips holding it on not tape. And of course they are easy to break.
    There's no 'I' in denial.
    2001, Ebony Black, 1153
    Not sure, been a while since I had the doors apart on the VX, but on corvettes they are riveted in place AND have metal clips to hold in place.
    Oct 2006
    01 Green Dragon 00291
    It is held in by clips, I think... . I seem to recall removing mine when I did the SBC brackets. I might be thinking of my other car.
    With the door panel off, you can see about 10 clips holding on the trim. They're mounted on a rail and need to be slid off. There is a section of the rail that has a break and that's where you can remove them.
    The clips are not difficult to remove but some will probably break.
    Jun 2010
    99, Silver, 1784
    Thanks guys, and particularly for those details, 'Rado. I'm sure they'll be most helpful to the shop.
    -V
    -V
    Just to elaborate, they're thin metal tabs on the door spaced every few inches, that you match up and slide into the holes on the hard plastic part of the rubber strip piece. (See pics)
    It's super easy to remove. Like Jon said, some tabs may break, but it's not that big of a deal, pbkid (Jack) used some type of sticky putty type stuff to hold mine in tightly. I subsequently got a replacement from a junkyard.
    ***DO NOTE- That strip has a metal core so it can be BENT VERY EASILY, and it's fairly hard to get it bent back EXACTLY right...so be gentle with it.
    Here's pics.
    Jun 2010
    99, Silver, 1784
    Thanks, Kat. I'll pass those pics along as well. Very helpful!
    -V
  1. Newb with rear door question
    By Espritmike in forum VX Modifications...
    Last Post: 07/05/2013, 12:21 PM
  2. Stupid Question: Taking the door apart?
    By Girlybot in forum VX Troubleshooting...
    Last Post: 07/26/2008, 11:34 AM
  3. door window change
    By xiaoz in forum VX Talk...
    Last Post: 09/27/2007, 07:43 PM
  4. Another Lambo Door Question
    By Baldwin in forum VX Modifications...
    Last Post: 01/24/2007, 03:53 PM
  5. Removing door panel for window fix
    By Raque Thomas in forum VX Troubleshooting...
    Last Post: 10/14/2006, 05:25 AM
