Results 1 to 5 of 5
Thread: Changing front and rear diff fluid
    Oct 2014
    2001 Ebony VX 1092
    I am thinking of servicing the front and rear diffs. And suggestions as far as what fluid/vescosity is best? Also, how much will I need for a complete drain and fill for both diffs?
    Thanks!
    Jul 2009
    Front diff, 1.5 quarts Amsoil 80w90 Synthetic Gear Oil. Rear diff, 2.2 quarts Amsoil 80w90 Synthetic Gear Oil plus 7 ounces CRC Trans-X Limited Slip Additive #402508. That's what I run in both of mine...
    Vixer Fixer
    Sep 2014
    2001, Foxfire Red, 1283
    It's kinda whacked but you have to remove the bottom bolt on the front diff cover to drain; the rear has a drain plug.
    Oct 2014
    2001 Ebony VX 1092
    Thanks for the advice guys!
    Make sure you take the fill side off first...to make sure you can get it off.
    Pretty frustrating to drain the diff and then not being able to fill it again...
  1. Changing tranny fluid??
    By Boonetown123 in forum Ldub's After Midnight Topics
    Last Post: 10/05/2014, 08:14 PM
  2. front/rear axle fluid change
    Last Post: 04/13/2008, 10:58 AM
  3. Replies: 2
    Last Post: 03/09/2007, 12:42 PM
  4. Need Front and Rear Diff low down.
    By VXNIT in forum VX Troubleshooting...
    Last Post: 01/14/2007, 10:29 AM
  5. Trasmission fluid changing at 36K
    By Billyphxaz in forum VX Troubleshooting...
    Last Post: 06/15/2004, 11:45 AM
