Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
Thread: overheating with ac on ALL READY!!!
  1. #31
    Jan 2014
    2001, Foxfire, VX, 1132
    Mine was also a FFDynamic fan... hmmm, maybe it's just an FFD issue? Inadequate CFM like OhioVX stated.
    I noticed my engine temp was creeping up on the interstate at 75 MPH cruising with the outside temp only in the 70's. I didn't want to chance keeping it installed for the summer and risk getting stranded.
    I'd like to go back to a electric fan as the throttle response was noticeably better.
    If you are having an issue on the freeway, it has nothing to do with the fan or shroud. It is a radiator issue or restriction issue (maybe thermostat) The only time a fan is needed is when you are going 25mph or less (traffic). Also if an electric fan has a fan switch that is too low, or is wired to be on when the ac is on. It can actually impede air flow on the freeway & cause an issue. That's why I got the higher temp fan switch.
  2. #32
    Quote Originally Posted by siemprelisto View Post
    Just wondering what a used Ron Davis radiator and shroud would sell for...
    As point of reference to start with, a NEW RD radiator was roughly $600 + $70 for packaging. Don't know what shipping is as I picked it up.
  3. #33
    0.01% more noticeably better
    I worked the math in my head one day on my commute from hell. T'ain't much.
    At least round it up to an even 2%!
    The mechanical fan clutch even sounds like a power suck.
    ...but I prefer a cool engine.
  4. #34
    Quote Originally Posted by ohiovx View Post
    It was definitely the electric fan. Without a doubt.
    Before installing the electric fan, I only had hotter temps under load for extended time with A/C running, i.e. driving up the mountain passes. With the electric fan, the engine started running hot without A/C on the flat freeway.
    Afterward, I purchased a $10 OEM fan clutch from a junkyard Rodeo and it surprisingly fixed the issue completely.
    Like I said before, it may have just been the FFD brand that was insufficient. I'm not suggesting all electric fans are fault, but I have found many VXers with electric fans tend to have some overheating issues.
  5. #35
    Jan 2014
    It's gotten a little hotter here lately. Actually got up to 90F one day with about 90% humidity ( the Humidity is what matters with AC). & my Custom Shroud & 16" ebay electric fan cools it fine. Even had to sit still for a funeral procession for almost 1/2 hr with the A/C on. The biggest thing is the shroud. Mine is not your run of the mill shroud you buy from JEGS. & the switch I use to turn it on comes on at 210 & goes off at 195. So if you have good airflow on the freeway the fan isn't on. If you have the wrong temp switch & it is on when you are going down the freeway it will slow the airflow through the radiator, causing a loss of cooling. If your cooling system is working properly when going down the freeway with good air flow it shouldn't get up above 195F. So no fan should be needed. Seriously, In my professional opinion If you can't get an electric fan to cool your VX, you are missing something. If a Mechanical (fan clutch) can cool the vehicle. A properly designed electric fan setup can also. An aftermarket state of the art radiator can help, but it seems to me. if you want to loose the direct connection (fan clutch) you need to get a shroud like mine custom made for the vehicle.
  6. #36
    Did anybody tried to disassemble clutch to see if there enough fluid in it?
    (That's why it's not working right?). On another car I have (LX450) I bought AISIN and put 20000CST in it-seems solve my o/h problem.
    Also, when you just start cold engine, put rolled newspaper to fan-and if it will not stop it (On LX I could stop fan)-than you fan clutch is good.
  1. overheating already
    By angeno in forum VX Talk...
    Last Post: 05/15/2014, 09:42 AM
  2. help overheating
    Last Post: 09/03/2010, 11:32 AM
  3. Getting the VX tow-ready
    By Travelin2 in forum VX Talk...
    Last Post: 10/07/2009, 10:52 AM
  4. Overheating
    By bobmumgaard in forum VX Troubleshooting...
    Last Post: 06/27/2007, 01:51 PM
  5. VX DVD is ready
    By tiggergreen in forum VX Talk...
    Last Post: 01/08/2004, 07:31 PM
