Results 1 to 7 of 7
Thread: More Tranny Issues :(
    Oct 2014
    2001 Ebony VX 1092
    So the other day I drained and filled my tranny. When I drained it, only about 3 1/2 quarts came out. I didn't drain the cooler lines or try to get any out of the torque converter or anything. I didn't really want to drain it ALL anyway as I've heard it is not recommended when the fluid is burnt. So anyway, took 3 1/2 quarts out, put 3 quarts in plus about half a quart of Lucas tranny additive (not the stop leak stuff). I filled it until I got a steady dribble out of the check hole (yes I was on a solid FLAT surface and the truck was up to temp). Before the fluid change i was experiencing a slight late/hard shift intermittently. When I first changed it, it was shifting super smooth. But now almost a week later, the problem has worsened. Late/hard shifting at times and twice now it has refused to go into second gear. I've had to put it into neutral and then back to drive and it will shift. So my question is, am I doomed?? Or is there something I can do/try to fix it? Any advice is greatly appreciated as always.
    Thanks!
    Check your fluid level by following this from the shop manual:
    Fluid Level
    When adding or changing fluid, use only DEXRON )–III.
    Refer to Maintenance and Lubrication in General
    Information section for maintenance information and
    servicing interval.
    CAUTION: DO NOT OVERFILL.
    Overfilling will cause foaming, loss of fluid, abnormal
    shifting and possible damage to the transmission.
    1. Park the vehicle on level ground and apply the parking
    brake firmly.
    2. Check fluid level with engine running at idle.
    NOTE: Be sure that transmission fluid temperature is
    below 30C (86F).
    3. Move the selector lever through all gear ranges.
    4. Move the selector lever to “Park”.
    5. Let engine idle for 3 minutes and open the overfill
    screw (1).
    6. Add released transmission fluid until it flows out over
    the overfill screw opening.
    7. Let engine idle until a fluid temperature between 32C
    (90F) and 57C (135F) is reached, then close the
    overfill screw (1).
    Torque: 38 N•m (28 lb ft)
    Matt,
    It sounds like one or more of your shift solenoids could be bad. There's a recent thread on the topic (including links where to buy the solenoid kit). Prolly about $300 DIY in your driveway.
    Oct 2014
    2001 Ebony VX 1092
    Thanks Tom, I'll check it out.
    Oct 2014
    2001 Ebony VX 1092
    I found the post Tom. Sounds like solenoids could definitely be my problem. I figure I'll probably remove and clean the shift sensor like they discussed in the other post just for the hell of it. I have not noticed the shift position lights on the dash jumping around, however, it does not register that I'm in drive 2 at all. I also have a slight fluid leak at the shifter seal that I can fix at the same time. I saw a video online that shows you how to adjust the bands in our transmission. Do you think that would be worth doing while I'v got it torn apart? also, I couldn't tell in the vide if the band adjustment was on the top of the tranny, or if it's under the pan? Anyone know?
    Oct 2014
    2001 Ebony VX 1092
    here's a link to the video: https://www.youtube.com/watch?v=bHWDxAwhzYc
    Oct 2014
    2001 Ebony VX 1092
    now I can see. it is definitely under the pan. Anyone here ever adjusted the band on their VX?
  1. Having two Issues....
    Last Post: 05/18/2012, 01:47 PM
  2. Tranny slipping issues....?
    By Breezy in forum VX Troubleshooting...
    Last Post: 09/04/2011, 09:59 PM
  3. New Issues!
    By Mrcln1 in forum VX Troubleshooting...
    Last Post: 10/01/2009, 10:16 PM
  4. outline of tranny filter on tranny pan......
    Last Post: 05/16/2006, 08:44 PM
  5. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 03:41 AM
