Results 1 to 7 of 7
Thread: Did I screw up my timing? Timing belt replacement
    Dec 2006
    Thumbs down Did I screw up my timing? Timing belt replacement
    Ok, I took the plunge to replace my timing belt at 122K; I was on borrowed time. I'm using Bart's How-to and got to the point of successfully aligning both Camshaft and the Crankshaft green reference marks. I could not make out any lines on my original Isuzu belt; I had no markings remaining and I couldn't see the dotted line that is supposed to be at about 8 o'clock on the crankshaft. So I did about one full revolution and aligned the three reference marks. When I released the push tensioner, my camshafts pulleys sprung to RH 9 o'clock and LH 3 o'clock. Bart's How to says they should both spring to 12 o'clock)
    So...am I in trouble here? Am I 180 degrees out? Can I install the new belt while pulling the camshafts back to midline to their reference marks (if they were both at 12 o'clock you would pull both to the outsides to get to the 10 and 2 reference marks) or do I need to go through the scary-sounding instructions for when camshaft timing has been disrupted?
    Any advice is appreciated. Call if you'd rather. I'm worried and really need the VX next week for work. Thanks, Bren.
    Bren Workman
    Gretna, NE
    (C) 402-312-1992
    Dec 2006
    I'm looking now for how to retime the camshafts. I found the tutorial also in the How-to section, that basically says to rotate the odd bank camshaft (passenger side) until it pops into the 12 position. The even bank is supposed to pop to 9 first, then continue rotating and pop to 12. I'm cautiously going to try this now.
    Dec 2006
    With multiple "snaps" at varios positions, both camshafts' reference marks have snapped to the 12 o'clock position. With the crankshaft also ar the 3 o'clock position, hopefully I'm fine. The Workshop Manual is useless for info. on setting crankshaft timing. Fingers crossed.
    Oct 2002
    01 Proton 1131; 01 Proton 0504; 00 Proton 0695; 00 Ebony 0285; 00 Foxfire 0032 Donor VX; Complete S/C Engine on Stand;
    @workmeistr
    I have not done the timing belt as yet.
    From what I have read and have come to understand, this is non-interference engine. Therefor you should not have any problems spinning your crank or cams into position.
    Good luck...You'll get it done
    Dec 2006
    Everthing turned out fine. Bottom line, ensure camshafts snap to 12 o'clock. If they don't automatically when removing belt, just do it afterwards. As long as the Crankshaft is on its mark, all will be well to do the Camshafts afterwards. After installing the belt, I turned the Crankshaft many revolutions to ensure all three marks lined up correctly. Thanks also nfpgasmask Bart, for words of inspiration. If anyone is contiplating or on the fence about doing the job yourself, feel free to call me and I can help you through the process. Bart's How-to was a life saver and I'm glad I did the job myself. It gives me peace of mind that it's done right and saved me a bunch of dough.
    Congrats Bren...nothing like that feeling of accomplishment!
    GTK Bren. I may need to call you whenever I get back to working on Boy's VX. I'm pretty sure we lost timing reference whenever we were replacing head gaskets.
  1. HELP!!! timing belt replacement parts
    By ben-man in forum VX Troubleshooting...
    Last Post: 12/30/2015, 07:07 PM
  2. Timing belt replacement disaster
    By Gable74 in forum VX Troubleshooting...
    Last Post: 10/28/2015, 11:27 AM
  3. Timing Belt......
    Last Post: 11/03/2009, 06:39 AM
  4. Timing belt replacement and timing videos
    By deermagnet in forum General Tips...
    Last Post: 11/26/2007, 09:09 PM
  5. Timing belt replacement and timing videos
    By deermagnet in forum Archives
