Update...And then GOD (or maybe it was Jason!) said let there be Engine Timing...She started and ran better than ever!!
Jason you were 100% correct about the 1.5 turns being sufficient...So here is the summery of the last thing that I did that reestablished timing:
1- With the timing belt removed, I turned the Crankshaft sprocket to the TDC position (The halfmoon cutout on the crankshaft sprocket was at 3 O'clock matching with the timing hatch mark on the oil pump cover
2- I turned the RH Cam (Passenger side) at least 9 times (it really was not necessary, but I wanted to be sure), then I turned it more until the Cam pulley sprung back to 12 O'clock (using the Timing reference mark on the Head...10 O'clock using a real O' clock), on its own.
3- I turned the LH Cam (driver side) at least 9 times (it really was not necessary, but I wanted to be sure), Then I turned it more until it sprung back to 9 O'clock on its own (using the Timing reference mark on the Head), on its own, then I turned it 90 degrees clockwise until the timing mark on the Cam pulley as aligned with the timing mark on the engine at 12 O'clock (using the Timing reference mark on the Head...2 O'clock using a real O' clock). I let go of the ratchet and the Cam stayed in the same spot...It did not try to spring
4- I aligned the two lines on the belt with the timing mark on the Cam Pulleys and made sure they were still aligned with the timing marks on the engine
5- I aligned the double line (my belt had a double line instead of a dotted line) with the timing mark (NOT the TDC notch) that has a green dot of paint on the sprocket itself at roughly 9 O'clock 180 degree opposite of the TDC notch
6- I took a final look at all the marks and made sure everything was still aligned
7- I installed the tensioner, and checked all my marks again
8- I pulled the tensioner pin and made sure everything was still aligned
