Results 1 to 6 of 6
Thread: Shaking
    May 2003
    1999,black,vehicross 1724
    Shaking
    Whenever I hit the gas, my car is shaking hard and making a big noise.
    Why!
    I checked the engine mounting, and everything was alright.
    And I changed transmission oil 6month ago.
    Anyone coud help me?
    Aug 2003
    2001 Kaiser #0894
    gotta flat?
    push the winter drive button and see what it does. if it drives fine when starting in third you're probably grinding 1st gear. check the tranny fluid (while running)?
    dunno, i'm by no means and expert or heck even half-way edumacated about the matter, but usually when someone new to VXing has problems, it's just because they just changed fluids incorrectly. Our trannies are very sensitive to fluid level...
    i'm sure you'll find better help than this - a lot of folks on this board are QUITE knowledgeable on our trucks. might help if you elaborated on the shaking and grinding though.
    -scoob
    Do they ever stop looking?
    EGR
    Jun 2003
    99, Ironman VX, 1455
    Post What was shaking in my VX...
    Well, I had a similar problem that wouldn't go away. The case for me? The fan (I guess engine fan, the big spinning thing under the hood!!!) had worked itself loose and had to be replaced, the bearings were bad or something like that! I was skeptical at first, I think it cause around $150 or soemthing, but when I saw the old fan, I realized that it really was damaged.... I don't know how it happened, but the noise and shaking went away....
    How can you tell if it is broken? Just take the fan and feel around the center where it connects, its like a bicycle wheel in that it can be out of true or the bearings make it loose around the hold.... I am probably doing a shizz of a job explaining, but I hope you get the point...
    -The Rave-
    North Carolina
    May 2003
    THANKS! GUYS
    I LOVE THIS SITE.
    I LOVE YOU GUYS!! ( I AM A STRAIGHT GUY NO E-MAIL PLEASE ) HA HA HA
    Feb 2003
    Previous owner of:1999 White Vehicross Ironman 1970
    Vibes
    My VX gives off some good vibrations sometimes, and noise to go along with it.....I, however, have it narrowed down to the exhaust
    The price you pay to be different......
  1. Car shaking and pulling in rear can't drive
    By Mrmonk7663 in forum VX Troubleshooting...
    Last Post: 06/08/2010, 05:30 PM
  2. shaking at 40-50 mph
    By mdbomb in forum VX Troubleshooting...
    Last Post: 12/22/2006, 05:04 PM
  3. New Tires, Shaking & Speed
    By doubleadesign in forum VX Troubleshooting...
    Last Post: 09/12/2003, 10:09 AM
