Results 1 to 4 of 4
Thread: P0101 code and VERY rough running
    Oct 2012
    2001, Proton, 0586
    My 01 Proton started to run really rough. I have to keep playing the gas pedal to keep it running. It sounds like it is running 3 cylinder and smokes like it is RUNNING VERY RICH. Eventually it would show P0101 code. Sounds pretty straight forward, only it isn't. I have since tried two other junk yard MAS sensors with exactly the same results, so it is very unlikely that I am looking at THREE MAF sensors with the same problem.
    Thinks that I have tried/checked:
    Two other uses MAS's
    Compression
    There are 12V and 5V at the sensor with key on
    Ground is there when ECU is turned off, but whe ECU is on, it creates some resistance (around .3 ohm, just enough to no register continuity)
    Any other ideas?
    '01 Ebony #0939
    Fuel pressure regulator and fuel filter. Two relatively easy items to replace anyway.
    Oct 2012
    2001, Proton, 0586
    I know fuel filter fails by clogging up and making you run LEAN, but what about the FPR? Does it typically fail by reducing pressure or increasing pressure?
    '01 Ebony #0939
    A failing FPR has been known to cause both just because of erratic fuel flow quantity. It's been a somewhat common issue in VX's anyway, so if it's never been replaced on yours, it would be a good place to start.
    I only have about 45k miles on my '01, and I've already had to replace mine due to rough running.
  1. Rough Running after Timing Belt Install
    By kpaske in forum VX Troubleshooting...
    Last Post: 09/08/2012, 11:36 AM
  2. Rough Idle and throwing p0402 code
    By VehiX in forum VX Troubleshooting...
    Last Post: 05/10/2011, 01:25 PM
  3. Rough Idle
    By VX FIX in forum VX Troubleshooting...
    Last Post: 03/15/2006, 06:24 AM
  4. ride too rough
    By Prozach in forum VX Talk...
    Last Post: 03/10/2006, 01:33 PM
  5. A rough bit of news
    By geshaw30 in forum VX Talk...
    Last Post: 03/19/2003, 09:40 PM
