Results 1 to 6 of 6
Thread: O-Ring from hell
    Apr 2005
    99 BlacK 5654
    O-Ring from hell
    A continuation of Paul_A's "Water under inlet manifold" .
    Did anyone find the right O-Ring that goes on the Stat Housing by the thermostat for the heater pipe. I went through hundreds of them at AutoZone and found one that looks like it, but leaks. I tried finding one the last time I did it, but that broke apart too.
    High temp and coolant resistant. I've seen fuel or oil seals, but didn't want those.
    Terrible time with this. Thanks!
    Apr 2005
    99 BlacK 5654
    Apr 2005
    99 BlacK 5654
    My last step was to go to Ace Hardware and just experiment.
    Maybe this works?
    https://www.ebay.com/itm/Victor-C317...0AAOSweWVXc1kl
    ...if you need a pic.
    https://onedrive.live.com/?authkey=%...OneUp/seal.png
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Quote Originally Posted by AssyrianMe View Post
    As you may or may not know, Acura rebadged Isuzu Rodeos/Troopers for the Honda Passport/Acura SLX.
    You'll need to go to acuraoemparts.com, and look under the diagrams for the SLX. The part numbers are:
    1-09623-130-0
    9-09561-225-0
    I did this in March as I was swapping engines (for the 3rd time), and then again when I swapped engines a couple months ago (I transferred them over). I ordered 4 of each gasket for future use as I realized that nothing off the shelf would work and that these were getting pretty hard to get.
  5. The Following User Says Thank You to eternal21 For This Useful Post:
    AssyrianMe (12/26/2017)
  6. #5
    Apr 2005
    99 BlacK 5654
    Eternal21, thank you. You are a life saver. I had ordered a Honda part (https://www.amazon.com/OEM-Honda-913.../dp/B00BFDIL8E) OEM Honda 91314-PH7-003 - O-Ring (31.2X4.1)
    Now I ordered extra quantity of your suggestion.
    Thank you again!!!
  7. #6
    Sep 2010
    1999,VX, 2477
    Thanked: 8
    Thank you again!!!
    You're quite welcome, glad I could help. Happy Holidays
  1. abs ring bolt stripped
    By djvx in forum VX Talk...
    Last Post: 05/09/2011, 10:00 PM
  2. HELP I need a ABS tone ring?
    By RAZ in forum VX Talk...
    Last Post: 08/29/2010, 01:25 PM
  3. Abs tone ring
    By erland in forum VX Troubleshooting...
    Last Post: 11/18/2009, 01:53 PM
  4. ABS ring behind front rotor
    By Bob in forum VX Talk...
    Last Post: 04/21/2009, 10:13 AM
  5. Snap Ring Size Help!!!!
    By Bimati in forum VX Talk...
    Last Post: 06/02/2007, 08:19 PM
