My vx has been over heating for about 4 months now. I replaced the radiator, the cap and new antifreeze . Even tried straight water in it. It over heats in wintertime or anytime no matter what the temperature is outside. Now its over heats within 5 minutes sitting in the driveway. One day it got so hot it blew the bottom radiator hose off. I pressure checked it nothing leaked, checked it all the way into the red zone on the pressure gauge and popped the upper radiator hose off. Fan turns always when vx is running. Water is flowing through all hoses, all hoses are hot. Fan and clutch does not wiggle and spins tightly. Water pump does not make noise, and pulley is not loose or play in it. Two days ago removed radiator cap , started vx little blue smoke came out tail pipe, bubbles came out of radiator and water looks light creamy color but not thick. Checked engine oil, trans fluid, and plugs all look great. Put the radiator cap back on started it within 5 minutes again heated up heard water sizzling under the intake. I figured I had a leaky hose under there. Snatched the intake off, no sign of leakage under it. Took the thermostat out tested in a pot of water on the stove , started slowly opening when got hot at boiling it was fully open. Does anyone on here know what may be making it get hot so fast and the water to be light creamy color? Could it be a internal head gasket letting small amounts of oil into the water ports and heating up the engine but not getting into the engine oil? All this is happening while idling within 5 minutes. Thanks for any help or information someone could give me.
