Results 1 to 3 of 3
Thread: EVAP check engine light
    May 2018
    2001 Black Vehicross 0535
    So I keep throwing an EVAP code, cant remember the numbers right now, but it seems related to going heavy or full throttle it will throw the code. Any insight on this? Where should I start looking.
    Thanks
    Jan 2015
    1999 Ebony VX, 0209
    Thanked: 19
    Options (without knowing the exact code)
    1) New gas cap
    2) Spray WD-40 on the gas cap seel and clean it really well.
    Without knowing the code, it’s the most common place to start.
    May 2018
    Thats what I figured, I tried screwing the cap on tigher than normal but to no avail. WD-40 on the seal sounds like a good trick. Ill see if I can find the paper the auto store printed out for me, its got the code on it.
  1. passing emissions with an Evap Check Engine Light
    By bearandbee in forum VX Troubleshooting...
    Last Post: 11/18/2011, 02:38 PM
  2. Check engine light
    By Frank Willen in forum VX Troubleshooting...
    Last Post: 03/21/2011, 05:33 PM
  3. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  4. K&N = Engine Check Light?
    By JAFO in forum VX Troubleshooting...
    Last Post: 02/16/2006, 10:52 PM
  5. !#@*! Check engine light
    Last Post: 02/27/2005, 02:47 PM
