Results 1 to 1 of 1
Thread: Rear Sidemarker Conversion to Turn Signal
    '99 Ebony Black VX, 0339
    Wrench Rear Sidemarker Conversion to Turn Signal
    After performing Scott's excellent Corner Marker Conversion, I decided to do the same for the rear side markers (caution, may not be legal in your area
    Process is similar to the front mod (link above):
    1. Remove rear brake/signal/parking light assembly by opening rear door and removing the 2 screws on each side - assembly will pull straight once screws are removed.
    2. Attach a 18" ~18 gauge wire with a scotchloc (or splice in a wire) to the top most GREEN wire going to the top turn signal lamp.
    3. Remove 2 screws holding the rear sidemarkers in.
    4. Route the wire down from the rear lights to the rear side markers.
    5. Cut back black wire sheath (about 3") to expose the wires at the side markers.
    6. Cut BLACK wire about 3" back from socket.
    7. Tape up black wire going down sheath.
    8. Attach the wire you ran down from the rear turn signal and butt splice or solder and heatshrink the wire to the black wire you cut going into the socket.
    9. Test before reassembling lighs - rear side markers will now blink in snyc with the rear turn signals when the parking lights are off and alternate with the rear turn signals when the parking lights are on.
    10. Reassemble and enjoy.
  1. turn signal wire
    Last Post: 10/26/2015, 07:04 AM
  2. turn signal help
    By dsallade01 in forum VX Troubleshooting...
    Last Post: 06/28/2011, 08:44 AM
  3. front flasher - turn signal not working, no power - rapid flashing of rear
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 03/17/2011, 06:38 PM
  4. Turn Signal Lens
    By SomeBeach in forum VX Talk...
    Last Post: 07/01/2009, 08:05 AM
  5. turn signal problem
    By hemicross in forum VX Troubleshooting...
    Last Post: 02/10/2009, 01:29 PM
