Results 1 to 5 of 5
Thread: Engine turns of sometimes
    Apr 2005
    99 BlacK 5654
    While driving, the engine could suddenly just turn off. I have to coast in neutral and turn it back on. All liquids fine and temp fine.
    It is completly random and can be every two weeks or every month.
    Could be fuel pump?
    Thanks
    Sounds like a dead short in the wiring. I had a 69 Camaro that had the Tach wire shielding wear a hole in it on my firewall...occasionally it would just dead short out and the engine would just die. Check with the Facebook group too...lot's of help available there as well.
  3. The Following User Says Thank You to Mile High VX For This Useful Post:
    AssyrianMe (04/10/2020)
  4. #3
    Oct 2014
    1999, Victory White, Ironman, 1567, 1999, Astral Silver(Painted Green Mica), Vehicross, 1454
    Does it tirn off while u are stopped at a light or when your cruising?
  5. #4
    Oct 2014
    Sorry re -read your previos post and says its when your driving not stopped! What speed does it normally happen and is your foot on or off the accelerator.
    Might be a bad TPS?
  6. #5
    Oct 2014
    If it shuts off while idling at a light the most probable cause would be a dirty throttle body.
  1. ac never turns off
    By FlyingV77 in forum VX Troubleshooting...
    Last Post: 02/05/2014, 07:09 PM
  2. LittleBeast turns 31
    Last Post: 04/25/2013, 04:39 PM
  3. My VX web shrine turns ten today
    By deermagnet in forum 10 Year Anniversaries...
    Last Post: 03/13/2012, 09:09 AM
  4. Moncha turns 10!
    By Moncha in forum 10 Year Anniversaries...
    Last Post: 10/11/2010, 09:13 AM
  5. Front tires squeek in turns
    By mikemol in forum VX Troubleshooting...
    Last Post: 10/04/2009, 10:10 PM
