Results 1 to 3 of 3
Thread: Rear Differential Help Please
    Jun 2005
    2001 Black VX
    hi everyone-
    I am looking for some help with my rear differential. It looks like the bolts holding the ring and pinion came loose, and I need a new ring and pinion as a result. I found NOS on isuzupartscenter.com, but they are pricey. Anyone have a line on anyone else who has them?
    Also, my mechanic is having a hard time finding a differential rebuild kit. He seems to think that the kits that he has found online have the wrong crush sleeve.
    I looked on Rock Auto, and the kit on there, DRK320, my guy claims is not the right kit for a 2001; specifically, the crush sleeve is the wrong one. Can anyone confirm that?
    To add to the confusion, there are 2 kits for 2001:
    Rear; 7.63 in. Ring Gear - 1st Design - 1.5 in. Seal I.D.
    https://www.rockauto.com/en/moreinfo...=2153&jsn=2153
    And
    Rear; 7.63 in. Ring Gear - 2nd Design - 1.69 in. Seal I.D. (this is also out of stock)
    https://www.rockauto.com/en/moreinfo...=2154&jsn=2154
    Any help is appreciated.
    Thank you
    Jun 2005
    2001 Black VX
    So the ring an pinion on isuzupartscenter.com would need to come from Japan. So that is out. I have sourced another one in the states. My questions still stand about the crush sleeves.
    Oct 2014
    1999, Victory White, Ironman, 1567, 1999, Astral Silver(Painted Green Mica), Vehicross, 1454
    Measure the diameter of your pinion shaft? That should tell you the right seal and kit to use if they changed the diameter of pinion?
    Anyone else agree?
  1. Rear differential
    Last Post: 11/01/2011, 10:55 AM
  2. Rear Differential Offset
    By waymore35 in forum VX Troubleshooting...
    Last Post: 06/20/2011, 08:11 AM
  3. How to replace rear differential
    Last Post: 06/11/2009, 12:47 PM
  4. Rear differential whine?
    Last Post: 05/21/2008, 09:45 PM
  5. Oily Rear Differential
    By Navigator in forum VX Troubleshooting...
    Last Post: 08/25/2003, 10:25 AM
