I talked to Rob at Advance Adaptors today about my conversion I am SERIOUSLY considering. I have to compile some info and will return to the internet to do my own research, but wanted to pose the question(s) here in case anyone else has info to offer...
First off... does anyone know the spline count of the TOD transfer case?
Second... does anyone know the bolt pattern of said TOD transfer case?
The answer to these two questions would tell me if the transfer case could just be adapted with factory/stock parts. If the transfer case has a 27 spline (I think that's what he said... left my notes at work! DOH!) count and a "round" six-bolt bolt pattern? If so, the transfer can be adapted EASILY. If not, it will be time to ask MORE questions of Rob.
Next... anyone have the torque ratings of the TOD transfer case? Will it handle the torque that a LS1 and 4L60E will dish out? Or, will it just blow up?! I know that ONE of my LS1 Trans Am's put 310 RWHP and 324 lbs/ft torque... completely stock. Not sure exactly what that figures at the crank, but I'm sure its well over 345hp and somewhere around the same on the torque number.
OK... more questioins... Dimensions... anyone know the amount of space between the frame rails of the VX? Or, does anyone know the width of the 3.5L motor? Rob said that they can't fit the LS1 into the Toyota's because the LS1 is nearly two inches wider than an older SBC. I guess if it were close, I could trust my welder to channel the frame a little if needed... but hopefully we don't need to go there.
One more... I think I know the answer to this one though. In the event that I have to dump the TOD transfer case... Rob wanted to know the offset of the front axle... the differential housing is offset the the right (passenger side), right?
Alright... I'm off to a long night of research... I have to find this info in a hurry... I have my eyes on a motor/tranny combo that has EVERYTHING I need... don't want to let it slip by if this is gonna be the route to go.
BTW, I found out why Advance Adaptors has a disclaimer saying that they no longer support Isuzu Trooper conversions... Rob actually let out a sigh when I told him what vehicle I was working with. Aparently, Isuzu was regularly changing the spacing and layout of the drivetrain... he said you could compare TWO trucks produced within a week or so of one another and they would have DIFFERENT tranny and transfer case spacing. I guess that caused some problems and so they threw in the towel. lol
Anywho... I'll be online... researching... if anyone wants to talk shop and is using AIM, drop me an IM at GiveWedgie. I'll TTYL!
