ok i know how much oil the trany takes
but do i check it from cold,hot, do i have it running or not???????????
thanks all
thanks all
not sure, but you just sounded like a Dr. Seuss book...
Habut do i check it from cold,hot, do i have it running or not???????????
running and up to temp. shawn
1COOLVX
thank you very very much
Check at idle, warm in neutral. Do chock the wheels.
John C.
chock the wheels???
Block at least one of the wheels on both sides so the VX does not roll while in neutral and kill you or damage something else while you are checking the level.
Jonnie
Do I check it with a stick?, what if the oil's really thick?Originally posted by Cyrk
Ha
You can check it at your house, you can check it with a mouse. You can check it wearing a hat, you can check it lying on a mat.
You can check it on your lawn, this crap goes on and on!
LMAO!!!this crap goes on and on!
________
WEB SHOWS
all this from a simple question?
you guys are crazzzzyyy
lololololol
I can not check it with a stick, there is no stick is this a trick? You have to check it with your hand, just crawl under in the sand. Start it up and pull a bolt, check with finger look for smoke. If it's low, not to the top, fill it up, it over-flows now stop! Once a year the filter you should replace, it keeps a smile on your face. You do this with your hand, but you have to drop the pan! Now that you are done, go have some fun, 4 x 4ing in the sun!
Dave...
Always a kid at heart!
applause;
clap clap and so on
lol
VXMAN you succesfully crossed the line
;pg;
Do they ever stop looking?
