Results 1 to 15 of 16
Thread: Driveshaft
    Jan 2004
    2001, Kaiser 1188
    Question Driveshaft
    I stopped by the dealer today because when I brake hard and let up, sometimes I hear a "thud." Not a big deal but I wanted to make sure it wasn't something serious. The dealer spent 8 hours with my rig (no loaner for me) and then came back and said the driveshaft had "moved a little." WTF!? He also said that it was very common to this model and to the Ford Ranger. They offered to replace the driveshaft but said it would move again in 10k miles. What is this BULL*****?! Sounds like they don't know wtf they're talking about (probably because they're a Ford dealer) and they had to make something up.....
    2001 Proton VX #0662
    Everyone says that's normal. When you brake hard the tranny doesn't have time to shift all the way down to first gear before the transmission stops turning, so when you let off the brake that thud is just first gear engaging. You just wasted 8 hours listing to BS at your shop.
    Canadian VXer!
    Jan 2004
    2001, Kaiser 1188
    Yup, that's what I figured....Somebody is going to get punched in the head for this.
    Mine does that too
    How normal can it be? In 25 years of driving the VX is the first car to do it for me. Anyone else get the thud when they brake hard then let up?
    I Loved My Space Buggy
    2000/Proton/0651
    I use to get it a lot, but now i have new transmission and haven't really noticed it. I'll try and listen for it. As for a good dealer in Denver VXRanger, go to Courtesy Isuzu on S. Broadway. They're awesome!
    2001, Proton Yellow, #0580
    I've felt/heard it. I thought it was the Interceptor at first, but the Interceptor only adjust pressure during upshift.
    -- John
    Jan 2004
    2001, Kaiser 1188
    Thanks Tonka! I was actually down there looking at an RSX-S...Good to know they're reliable. They actually had a 2001 Ironman when I was there.
    2001foxfire0203
    Did Isuzu make a 2001 IRONMAN?
    2000/Proton/0651
    I have been listening for it and i can't hear it. There is a small thud but no clunk like before. I would try changing the transmission fluid. It might be old and burnt. My VX started leaking transmission coolant (something like that) and turned my trans-fluid black! It started leaking again and i started having lots of transmission problems. Dealer replaced the whole tranny for free! Thank god for the warranty.
    Yes, the ironmans are the white VX's. And that one on that lot i want parts off of. My VX is showing some wear and tear. I need to get a couple things.
    Nov 2003
    '01 Kaiser Silver, 1138
    Glad to hear the "thud" is common - I guess I'm glad. I noticed the thud at times right away and wondered what it was.
    Has anyone heard a humming from the back that speeds and slows with VX? I thought it was my worn tires, but its still there after getting new tires and an alignment. It may be normal for a VX, but thought I'd ask in case its the start of something serious. Rear diff or transfer case low on fluid? Wheel bearing?
    JT
    JT
    Yes "Thud" is common especially when unexpected braking occurs.
    Got the "Humming" sound when I first got my VX. Dealer could not find anything wrong.
    Fix: Install Subwoofers
    The Bantan's Relm
    Gallery
    Myspace Page
    Jan 2004
    2001, Kaiser 1188
    hahahah! good thinkin'
    It means your VX likes you.
    It is good to hear this is normal because this "thud" is very common for me too. My first educated guess would have been that the U-joints were going bad.
    '99 Vehicross - Daily Driver
    '93 Wrangler - Tank in Progress
    99' Astral Silver
    The thud happens to me and I also have the whine at lower speeds. I contibute this to fluids. I'm going to lube the driveshaft and change out the diff and axle fluids. We'll see what happens after this.
    Live Free or DIE!
  1. Possible driveshaft parts source...
    Last Post: 06/16/2012, 10:39 PM
  2. TOD and no rear driveshaft....
    By Marlin in forum VX Troubleshooting...
    Last Post: 09/03/2011, 11:38 AM
  3. Need a new driveshaft!
    By VXIRONwoMAN in forum VX Troubleshooting...
    Last Post: 08/10/2010, 08:57 PM
  4. front driveshaft removal
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 11/28/2007, 11:04 PM
  5. Driveshaft/Train Noise
    By -x- in forum VX Troubleshooting...
    Last Post: 02/19/2003, 05:57 AM
