Results 1 to 4 of 4
Thread: Grease fitting help.........
    Feb 2003
    .help.........
    ok, I'm trying to grease everything up under my VX(;Dp; ) and I can't seem to find my Torsion bar Bushings to grease.
    I guess they are way up there and hard to see. Does anyone know exactly where they are at???
    2001 Proton VX #0662
    I wonder if the torsion bars even have grease-able bushings!
    Canadian VXer!
    Dec 2003
    99 white Ironman 0922
    there are rubber bushings on the lower "A" frames, no greese required. Ball joints are sealed type unless you drill and tap for grease nipples. Correct me if Iam wrong but In general all you can grease on the chassis is the tail shaft and fron hub bearings.
    There are only 3 zerks on the VX (unless you have added the greasable sway bar bushings) - 2 on the front section of the rear driveshaft and one on the rear of the driveshaft. That is all.
  1. Help with fitting Rear 6x9's
    By frankd14321 in forum VX Troubleshooting...
    Last Post: 09/26/2012, 08:17 PM
  2. Best Synthetic Grease
    Last Post: 01/09/2010, 08:04 AM
  3. Grease Monkey Report...
    Last Post: 06/24/2006, 05:22 PM
  4. Grease Points ???
    By Kahuna in forum VX Troubleshooting...
    Last Post: 07/09/2005, 11:15 PM
  5. Replies: 3
    Last Post: 04/28/2003, 10:43 PM
