Results 1 to 12 of 12
Thread: Intake gasket. Do it yourself
    2000,black,029
    Well I just got done replacing my wife's intake gasket on her trooper. This will be the second on in 20k. If anyone has an issue with the intake gasket I highly recommend to do it yourself. There is an easy way to cheat and not remove the entire intake. It took me 2 hours and the dealer wanted $300 for the job. The only thing I had to remove was the egr pipe. If anyone wants the tips feel free to e-mail me at anpodnar@isza.com. I did it basically like I have done many 3.1L gm intakes. All you need to do is take off all the bolts and nuts from the intake and use a wedge under the intake and you can remove the gaskets and replace. Later
    Andy from Isuzu America
    just courios, any one try using "Phenolic " intake spacers to reduce heat tranferrence to the intake runners? dont know if their even available for the 3.5, but the 2.5 ford/mazda people rave about them... thought id ask, im still clueless about this power plant..but trying.....
    Maverick
    99' Ebony VX sold...
    The Isuzu ones ARE Phenolic...
    woohoo!! one less notch on the clueless tree for me...
    I like this truck!!
    Jun 2003
    Apparently some kind of inferior phenolic.
    Jun 2003
    1999, White, Ironman, 1626
    Sounds like a great write-up for the How-to section...
    2001 Proton VX 0790
    You'd have to wedge it up quite a bit, the front and rear fasteners are studs, not nuts. They are hex ended, so you may be able to remove them to make the process easier though.
    John C.
    Dec 2003
    99 white Ironman 0922
    I would suggest use of avionic gasket cement (shellac) on both sides of the gasket degreasing mating surfaces is mandatory. Let it semi dry before clamping. Definitely avoid silicone sealants!
    '99 Ironman, 0992
    Absolutely NOT - gaskets have a sealing substance already on them. Please refrain from giving out incorrect info for something you have not done yourself and tested.
    May 2003
    '99 Astral #1613
    Hey Jay, PM'd ya about something (unrelated)...
    Dec 2003
    Sorry to disagree, but I had very good luck with this method for many years on many vehicles even on ported intake tracts. I didn't have to change gasket on mine VX yet possibly because I re-torqued down most of the bolts after break in period. I assume that new VX gasket has self adhesive coating on it to keep it in place during installation, this adhesive/sealing substance may not be as effective as gasket cement which would explain the need to do it the second time within 20k on Andys454 wife's Trooper.
    FelPro has put out some publications in the past that deal with this subject.
    VX922
    '99 Ironman, 0992
    No PM on the site yet, shoot me an email.
  1. intake gasket
    By bulldog in forum VX Troubleshooting...
    Last Post: 07/12/2006, 01:29 AM
  2. intake gasket leak !!
    By psychos2 in forum VX Troubleshooting...
    Last Post: 01/02/2004, 08:49 AM
  3. Part # for intake gasket
    By deton8r in forum VX Modifications...
    Last Post: 05/10/2003, 02:57 PM
  4. Intake gasket
    By andy454 in forum VX Troubleshooting...
    Last Post: 04/23/2003, 06:05 AM
  5. Bad intake gasket
    By JRB in forum VX Talk...
    Last Post: 03/21/2003, 06:10 AM
